Old 12-21-2020, 03:31 PM
yop22 yop22 is offline
Default D-command crashes PT2020.5
We have purchased a d-command and some functions like banking on a pretty large session crash protools. And once is has crashed the session gets corrupted and can't be opened anymore.
There's also a fairly large amount of plugin mappings in the session.
It's on a Mac Pro 5.1 with High Sierra 10.13.6. anyone has experienced this ?
Win 10 pro, Asus Rog Maximus, i9 [email protected], 64GB
PTHD native, 2x96IO, SSL Delta Link, S3
Old 12-21-2020, 04:44 PM
francois's Avatar
francois francois is offline
Default Re: D-command crashes PT2020.5
Had some kind of the same issues last year before switching to a Mac Pro 2019 and Catalina. Did not think at the time that it was D-command related.
Could have been ,but I was leaning more toward mechanical HD corruption.
François
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 12-22-2020, 12:38 PM
Thanks, in our case it's definitely not a HD issue because disabling D-command in peripherals, solves the problem. It looks more like some D-command parameters are corrupted, either in the session file or in PT preferences.
Old 12-23-2020, 04:00 AM
crizdee's Avatar
crizdee crizdee is offline
Have you trashed all the prefs and uninstalled completely and then re-installed PT? this is the only way to refresh the d-command bundle. and also reset the D Command before booting the fresh install.
Chris
Producer, Engineer,
www.ukmastering.com
Best Interface PT2020 lampmusic Third Party Interfaces 7 06-05-2020 02:54 AM
How old of a MAC Pro if running PT2020? TB3? GrievousAngel macOS 5 05-11-2020 12:46 AM
Projects issue in PT2020 tamaman67 Pro Tools 2020 0 04-20-2020 10:35 AM
12.6 Mac Crashes when using D-Command Func buttons StefB Pro Tools 12 2 10-17-2016 11:03 PM
Command + clicking a plugin to stick it to the top of the menu crashes Pro Tools... Focuret Pro Tools 10 0 07-22-2013 11:47 AM
