freeze when adding tracks
this is an all-of-the sudden problem, started yesterday but now it's permanent.
using mBox with all the newest bits 5.2.1 etc. G3 pismo 500mhz, 1G ram, it all worked fine til recently. now if i try to open a session and add a track it freezes. sometimes i can start a new session, add a couple, but then adding a master fader freezes it. many times it freezes on startup when building the windows (in fact seems to freeze on building the status window...) just ran norton, techtool, rebuilt desktop, pram etc.. ummm...?
http://www.jonathansegel.com Mac Pro 5,1 3.06ghz 64GB RAM Macbook Pro 2.8Ghz 16GB RAM PT 2022.10 UAD-2 Apollo Quad, PCIE and Satellite |
Re: freeze when adding tracks
If you haven't already done so, trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac.
If the freezing persists, reinstall PT LE. But first, trash the following items before running the installer from the PT LE CD-ROM: from Hard Drive: -------Digidesign folder from System folder: -------DAE Folder (remove all third party plug-ins and custom presets) from Control Panels folder: -------Digidesign® from Extensions folder: -------DigiSystem INIT -------Digidesign Direct I/O -------Digidesign DSP Manager -------Digidesign Stream Manager -------Digidesign USB Driver From Preference folder: -------DAE prefs -------DigiSetup -------ProTools preferences Brent |
thank you thank you. here i was thinking it was some bigger problem.
i should have rememebered all that from when i was working at studios in the film post-audio worls in LA, had to toss those files every other day. i believe my problems came about from the fact that i have a couple applescripts to switch the digi sys init and dae so i can use either 5.2.1 or PT Free on the laptop, so i get two sets of PT prefs. works again now!
Freeze Tracks | Siegfried Meier | Pro Tools TDM Systems (Mac) | 27 | 04-19-2009 06:42 AM |
Adding tracks Mbox 2 pro | hbpllc2003 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-18-2008 02:41 AM |
PT 7.4 crashes when adding tracks | rreverman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-08-2007 03:24 PM |
Adding silence to tracks | JohnnyT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-21-2005 08:46 PM |
adding delay to tracks from tape | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-19-2004 05:34 AM |
