Old 10-05-2022, 08:36 AM
Kinst Kinst is offline
Default Izotope eq as a default plugin issue
Hello! There is such a bug - I try to set Izotope equalizer (both Ozone and Newtron) as default and on a stereo track it opens as a mono plugin. Has anyone experienced this? What can be done?
Pro tools 2022.7, Mac Os Monterey, Izotope Ozone 10, Neurton 4
Old 10-05-2022, 05:02 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: Izotope eq as a default plugin issue
I just tested.
Yes, the plug-in Neutron 4 Equalizer as a default EQ loaded as "multi-mono" as seen in one of my screenshots. That does NOT mean a stereo signal does only pass through the plug-in as mono. It is "multi" mono. The left signal and right signal do not mix. This EQ has a pan knob itself, but I didn't use it, so it applies the same processing to both sides.
However, as seen in my other screenshot, when I have a plug-in prior to my Neutron 4 EQ, MSpectralPan, I can make most of the signal go to the Left channel, and my PT track meter (Pre-Fader metering option turned off in "Options" menu) shows the signal AFTER Neutron 4 EQ is definitely NOT mono.
If you carefully test this like I did, and the stereo signal in actually is a mono signal out, then that is another issue!
However, it appears to behave correctly in my setup. I recommend looking in the Reference Guide regarding the differences between multichannel and multi-mono plug-ins.
Chances are if you're not doing Surround and just working with stereo and mono, multi-mono will do just fine. Don't really need to worry about it in many cases.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 10-07-2022, 10:24 AM
Nednednerb thank you a lot for the reply!
HTML code is On
Izotope rx7 cpu issue ShadeTek AAX Plug-ins 1 02-09-2019 11:25 AM
iZotope RX 1.3 issue Audio_Vision Pro Tools TDM Systems (Win) 21 07-12-2011 01:18 PM
IZOTOPE RX Plugin released Rick Sanchez Post - Surround - Video 0 04-02-2008 01:29 PM
Izotope RX plugin for Protools Studio Studio Pro Tools TDM Systems (Mac) 1 03-05-2008 08:59 AM
iZotope Vinyl plugin jvox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2004 12:05 PM
