Pro Tools "House Settings"//Session exchange
So I may be missing something re: this one, but I've always had a sneaky suspicion so I thought I'd bring it here.
It's always seemed to me that whenever I get a session from someone else or their PT rig, that a lot of the settings/prefs that I have go screwy. That is to say I feel like I 'inherit' the way they had their stuff (time line selection etc etc) Tonight I popped open a band's demo session to check the tempo, and when I switched back to our session something got weird w/ the WC settings and I didn't catch it right away, leading to me chase down some pops and clicks for a minute. Annoying to say the least... It is most common/noticeable w/ I/O, but I was wondering if any of you have any experience with this and if so if there is any kind of way to 'safeguard' it, or am I just imagining things/being a baby? |
Re: Pro Tools "House Settings"//Session exchange
autosave got turned off 3 hours later Melodyne caused a crash and holy s**t where's my back-ups Also midi offset got set to -500 prefs should be locked no? Chris
Well, Pro Tools uses the i/o and settings of whatever was saved in the session you're opening, regardless of your current set up. I find this to be a maddening feature. There should be a preference that locks your current set up, no matter what session you open so that the problems you just described can't raise their sneaky heads.
This has been happening to me for 3years. Only work around for me was to open up my own template before so digi makes it easy for templates now. Once you open up template everything should revert back to the way you had of set up except a couple of things. Digi should definitly have a safeguard to protect all of our settings. If there is one can someone please let me know
Macpro 2.88-4 Gig Ram,HD2,Big Ben,Rosetta 200,Dangerous D Box,Mercury Bundle + Studio classics bundle ,C/24,2-UA 6176,U87ai,Genelec 8050 & 8020,Logic,Final Cut Studio 2,Canon hxa1(hd camera)-Macbook Pro,Mbox 2 Micro.http://www.masterlinkstudios.com/.http://www.myspace.com/masterlinkstudios |
add me to the list of frustrated however most of my work starts and stays in house
but i have one client who does his LE work at home and comes in with a cluster _ _ _ _ of entangled IO on every session. option key and remove all in line is your friend move out there trashy plugs...select default in IO setting and then import yours from your personal template
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
My opinion is preferences should be divided between Console and Session preferences. Console (including i/o) preferences stay with the studio and session preferences go with the session. Ultimately when opening a session, you should have the choice to use yours or theirs. Old news. Hopefully the next release will include some or all of decade old requests I see on this board over and over again. :)
Peter |
Best, Brandon |
Yeah I think at least we should have the option to import the prefs with the new session or ignore them and go with the usual prefs (maybe except critical ones that might cause the session to behave like crazy). And I don't see why one session that's coming in from another studio should affect all the new sessions that are created after it.. Just doesn't make sense to me. There should be an option for this too like with the I/O settings.
Me too, I would LOVE to have better control over this -- I always want my mix and edit windows to show the same things, and I'd love to skip redoing all my favorite stuff when I open sessions from other people/studios.
A possible good way to go here would be for each session file to be "tagged" with the particular system it was created or last saved on. If you open the session on that same system, all the usual stuff loads like it does now. But if you open that session on a different system (even with the same configuration, just a different machine and/or cards), you'd have the option to pick what changes and what doesn't, maybe similar to the way the import session data window works now. I don't even want to think about how many hours of my life have been spent selecting what I want the edit window to show, then the mix window, then closing and reopening the session to turn on delay compensation, then redoing the IO setup.... Well, at least I'm getting paid for it. But I'd love to make a few $$ less per song and not have to deal with it! |
Hear hear!
Put me down for the option to import prefs in a session...!
He used to cut the grass...he was a very nice boy... |
"Pro Tools not responding" error and a very "laggy" session! Help! | drumbumd | Pro Tools M-Powered (Win) | 0 | 02-10-2012 05:37 PM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-18-2009 09:18 AM |
What would be the "Best" or "General" Quantize default settings? | Norm Mix | MIDI | 0 | 07-10-2009 12:38 PM |
