Old 06-01-2020, 06:35 AM
EricMulhern EricMulhern is offline
Default Weird Glitch Importing mp4: Pro Tools 10 on Windows 10
(I posted this in the Pro Tools 10 thread but no replies; but maybe this isn't Pro Tools 10 specific?)
I'm running the latest Windows 10 on a HP Pavilion laptop.
I just bought a new camera (Lumix DC-FZ80) that records video in mp4. I'm trying to import videos to Pro Tools 10 but I'm running into a weird glitch:
When I import a video into Pro Tools, at around the 10:30 mark in the video, the video jumps back to the beginning and plays from there. The total duration of the video clip doesn't change, which means that the end of the video is cut ~10.5 minutes short.
Weirdly, this doesn't happen at exactly the same time: I have two videos, one is 14:48 long and the other is 21:03. the first cuts back to the beginning at around 10:28, while the second cuts back at around 10:32. But a shorter video, say 5 minutes long, works just fine.
Anyone have any experience with this? Any ideas how to fix it?
Old 06-01-2020, 08:40 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Weird Glitch Importing mp4: Pro Tools 10 on Windows 10
PT 10 and Windows 10 is really stretching it. I had a video issue with PT 2020 and MP4, which used to import fine on previous versions of PT. Found Shutter Encoder and transcoded the MP4 to H264 and all was well. As always, YMMV.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-14-2020, 04:00 PM
That seems to have done the trick, thanks! Though, now the playback is horribly laggy... not sure if i'll be able to sync up the video and audio. Still, half a loaf!
Old 06-15-2020, 10:11 AM
The Weed's Avatar
I'm now on the latest PT 2020.5 and the latest Windows update to 2004 and, with the Processor Affinity optimization (Core 0 and 1 unchecked with 8 cores - Hyperthreading on) I'm able to import and run MP4 videos again and PT is snappy at 64 buffer.
SonoBus
Old 06-15-2020, 10:29 AM
leftalive leftalive is offline
Ive never personally had much luck with .264 in PT. I use Myffmpeg to convert everything to DHxHD via the stock preset, and it seems to work really well. (I mean, as well as video ever works in vanilla PT...)
Just did foley and sound design for a 15 min short using this method, and it went well.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Weird Glitch Importing mp4 on Windows 10 EricMulhern Pro Tools 10 0 05-24-2020 06:13 PM
weird system glitch musicalavtech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2009 02:50 AM
Weird C24 Glitch...any ideas? soupmoose ICON & C|24 6 07-27-2006 01:38 AM
Weird ProControl/ProTools glitch uno1234 Pro Tools TDM Systems (Mac) 1 02-17-2005 02:36 PM
