Old 02-12-2018, 02:22 PM
deflint deflint is offline
Default Basic Question from someone new to Pro Tools.
Another former Sonar user here trying to record in a mode Sonar referred to as Sound On Sound.
For example in Sonar I could start recording at measure 1 for 4 measures. Then record again on the same track, starting at measure 1, adding a part at measures 3 and 4.
When I try this in Pro Tools, starting from measure 1, it overwrites what was previously recorded.
Punching in abruptly cuts off previously recorded instruments that should fade naturally.
Thanks in advance!
Old 02-12-2018, 02:41 PM
john1192 john1192 is offline
Default Re: Basic Question from someone new to Pro Tools.
Thanks in advance!
not available in Pro Tools .. IF you Are wanting to Hear what was done on the 1st Take while recording on the 2nd Take ...
you could use playlists in cycle record but you are not going to hear each take on top of the last one ..
if i am reading what you are asking correctly ..
think of pro tools like a tape machine
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-12-2018, 04:36 PM
Thanks. I'll give your suggestion a try.
Old 02-13-2018, 05:34 AM
And use a separate track for each take if you want to hear each take as you're recording. And when done and you want everything on one track record the outputs of the individual tracks to one audio track. More work than what you had to do in Sonar though.
Jack
QAPLA!
Old 02-14-2018, 05:01 AM
Wawili_Sound Wawili_Sound is offline
I am pretty sure pre roll allows you to hear what is o the track before you punch in, Ctrl 1 on p.c bring us transport to which you can program pre roll. Have a gander at loop recording and creating new playlist. In preferences you can select create new playlist when loop recording. This allows you to work on one track and have multiple spill tracks if you like. This makes it easy to compile a take from several. You will need to change track display to playlist though.
Good luck
https://youtu.be/ziD-ViiHoXA
WIN10 12.6 HD Native, Omni, BlackLion XB192
Old 02-14-2018, 06:58 PM
bashville bashville is offline
Is this audio or midi? Just to clarify
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Very basic question re Pro tools 12 upgrade from 11 Soularandy Getting Started 1 07-06-2015 08:38 AM
Basic Pro Tools midi question jakedavis Pro Tools 10 18 03-12-2013 12:18 PM
New To Pro Tools - Basic Question DStorms Pro Tools 10 4 12-30-2011 11:47 AM
Basic Pro Tools question Marjoth Tips & Tricks 9 09-14-2009 10:19 AM
Basic Pro Tools use. Really Basic question. Shizznik_McRuube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2002 11:41 AM
