Old 11-01-2017, 09:34 PM
Multiguy Multiguy is offline
Default Pro Tools Reopens after Exiting
I'm running Pro Tools 12.7.1 for Windows. Recently, whenever I'm done working and I Exit the software, it closes down then tries to restart and gives me this message:
Assertion in "..\ ..\ Sys\ Win32\ Sys_FileLocWin32.cpp", line 548.
I'll then close it again and it will stay closed. Next time I run the software it opens correctly.
Anyone else experiencing this?
I'm running:
PT 12.7.1 for windows
Windows 10 64-bit
16 Gb Ram with Vienna Ensemble Pro Slave
Dell XPS 8900, i7-6700 CPU
Scotty Huff
Nashville, TN
Main DAW:
Dell XPS 8900, Win 10 Pro, 16Gb RAM, UA Apollo Twin Duo
Vienna Ensemble Pro Slave:
Dell Precision T3600, Win 7 Pro, 64Gb RAM, VEP 64-bit
Old 11-01-2017, 10:12 PM
Default Re: Pro Tools Reopens after Exiting
It's not "closing down" it's crashing on an assert. Pay attention to this, who knows what could happen, lose sessions, updates, corrupt sessions etc.
Often caused by a plugin, including using rewire, or maybe a corrupt session.
You have some trouble shooting to do to find the problem.
Old 11-01-2017, 11:00 PM
Southsidemusic's Avatar
What Darryl said
I would start by trashing preferences and databases before i try the below idea.
Link here: https://www.sweetwater.com/sweetcare...s-preferences/
Also this can be caused by plugins not used in any session so if this happens on all sessions you might wanna start there.
Make a new folder on your desktop and Move all your plugins to the new folder.
Then you would add maybe 4-5 plugins at a time until all are added and see if that did it. Make sure you go thru All of them before moving on to the next step
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-28-2019, 11:01 AM
jpumphandle jpumphandle is offline
Thanks for the info concerning the "Assertion". This solved my problem. Now I just have to find the culprit plugin that is causing the grief.
I don't regularly use Protools because there always seems to be a workaround that I did not know about. Instead of just posting the actual error, Avid should be handling this kind of error and pushing on.
But thanks to you I am no longer dead in the water.
PT Closes and reopens every session at opening veet Pro Tools 12 0 04-07-2016 03:24 PM
Access/DEP Violation when exiting Pro Tools 12.4 wxs3 Pro Tools 12 8 02-24-2016 06:23 PM
Pro Tools 10 Delays or Freezes when exiting application abrstudios Windows 11 10-25-2011 02:20 AM
When Exiting Pro Tools Getting R6025 Error David H. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-20-2008 08:41 PM
Akai MPD-24 causing Pro Tools LE to Hang While Exiting..!!! Spyda KB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-08-2008 02:34 PM
