Stereo mic for drum overhead? pro\'s cons
Been thinking about getting a stereo mic and wondered what opinions are for use as a drum overhead or other apps like accoustic guitar etc. Looking at a Shure VP88 quite cheap at the moment! anyone used one? Chris
Re: Stereo mic for drum overhead? pro\'s cons
I always use the Royer stereo ribbon mike (SF-12)... sounds great.
I never liked the coincident stereo mics for overheads. Not enough stereo separation and control (i.e. you can't move one mic closer to the ride) for me.
I like the audio technica 825 alot. sounds much more expensive than it is
If only I could afford it
I worked on a couple of documentaries in a studio last spring that had two of them. One was dedicated as a drum overhead. (they also had every other piece of gear and instrument you can imagine) It was an inspirational wonderland. |
If you've got an opportunity to pick one up cheaply, by all means, snap it up. You'll be certain to get a lot of use out of it. Lee Blaske |
i just did a test of many overheads.........451's still sound like hit records, a AT 825 is an excellent mic for the money.
if you feel you need to have vintage ribbon mics as overheads, royers sound good and so do coles, youre gonna need some good and quiet eq though. Lots of choices.....listen in your room with your kit and see.
www.LiveFromDarylsHouse.com |
Hey Chris -
I've found that with recording drums, I need to spread my overheads apart to pick up the cymbals that are on the far right and left of the kit, otherwise they sound light. BTW - I'm using CK capsule 451's and getting excellent results. HTH.
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
I'd suggest getting 2 Nuemann TLM103's. You can experiment with placement/spacing, and you'll have 2 mics quite useful for other things. I never cared much for the Shure VP88. Just my 2 cents.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
I bought a TLM103 and it was way to bright for my liking, so i sent it back. Chris Quote:
Yes this was my main concern! i have never used a stereo mic for overheads, i have tried the coincident pair technique and that was ok as i remember, but that was when mono compatibility was more important!! but now?? Just thought a good stereo mic would do me for overheads and give me something different for accoustic gtr and other accoustic instruments!! Got my eye on a AKG C422 Chris
Quicktime Pro who's using, pro's cons | crizdee | Pro Tools TDM Systems (Mac) | 11 | 03-14-2006 02:51 AM |
Pro's and cons over a power mac G5 | AM STUDIOS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-12-2005 11:03 AM |
Drum overhead suggestion | WRX07 | General Discussion | 8 | 03-14-2005 07:52 PM |
ADAT vs 8 channel D\A w\lightpipe, pro's & cons. | audio junkie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-26-2002 12:22 AM |
what are the pro's and cons of using the dithered mixer | spong | Pro Tools TDM Systems (Mac) | 4 | 02-03-2002 03:16 PM |
