Pro tools 9.0 n 9.3 says app crash wont open upon launch
Hi
Pro tools 9.0 n 9.3 says app crash wont open upon launch. I have windows 7 professional 64 bit 18 gigs of ram i7 processor Mbox pro 2 Rosetta 200 I have already deleted prefs & data base Ive reinstalled mbox pro 2 driver I still get this Please help Thank you |
Re: Pro tools 9.0 n 9.3 says app crash wont open upon launch
Have you tried updating to SP1.
Have you tried launching with Run As Admin. Was Pro Tools 9.x working before, if so, what has changed? Did you install the driver Before you installed PT9.0 Quote:
Windows 7 Optimizations A Sandra may be helpful as well.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Yes I have updated to service pack 1 several months ago Yes I always run as administrator Yes it was working two days ago Yes I installed the driver first. Pro tools 9.0 has been working fine for a while now. Today I launched it and it wouldnt open says app crash so I though maybe nows a good time to update 9.3 so I did and it still says app crash Problem signature: Problem Event Name: APPCRASH Application Name: ProTools.exe Application Version: 9.0.3.80 Application Timestamp: 4dcf574c Fault Module Name: ntdll.dll Fault Module Version: 6.1.7601.17514 Fault Module Timestamp: 4ce7ba58 Exception Code: c0000005 Exception Offset: 00046cf4 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 SUCCESS! Ok I just remembered a few days ago I did the Windows 7 opto I forgot to click on pace. I just did msconfig again and did the usual routine and this time I made sure I clicked on PACE did a reboot and now pro tools 9.3 opens! Thank you! |
Did you try updating the iLok drivers?
www.ilok.com Updating Quicktime has worked for me in the past, so maybe give that a shot. http://www.apple.com/quicktime/ Also clearing out the reg has helped, I use Ccleaner www.ccleaner.com You can also use Ccleaner to turn startup items On and Off instead of using Msconfig. If you have installed other software lately it may be a driver conflict that gets started at boot up, so try disabling some stuff in the start up menu. Some Adobe products can cause AppHang errors. Try updating your video card drivers. Have you tried a complete uninstall of Pro Tools, then re-install? EDIT: I see you got it worked out, so disregard.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio Last edited by Benoni; 08-27-2011 at 01:35 PM. Reason: OP has figured out problem |
Pro Tools Update Wont Launch | L Stephens | macOS | 9 | 10-07-2013 03:32 PM |
M Powered Pro Tools 8 Wont Launch | gnicks18 | Pro Tools SE and Essential (Win) | 0 | 10-17-2011 04:56 PM |
Por tools LE 7.0 wont launch | Starhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-03-2009 07:12 AM |
pro tools wont launch | kguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-10-2008 10:11 AM |
pro tools r2 wont launch | ovo | Digidesign Hardware & Software | 0 | 12-26-2000 07:05 AM |
