#21
Re: 9.0.2 Not Communicating With 003 Rack+
Working now. But having the line issue.
"Well bartender it's a pain to see. I'm the bad mother [bleep][bleep][bleep][bleep]er called Stagger Lee" |
#22
A while back I had a similar problem. Somehow I had remnants of old drivers/software that wouldn't go away - specifically my 002 driver seemed the worst offender. Sometimes I would have two drivers in device manager listed, sometimes just rogue old files on my hdd.
It came down to uninstalls not completing correctly because I had my pc setup for internet access (with all the drivers and services associated with that). No errors in setup, just I could see it wasn't cleaning everything out. Once I got off the internet, ran all PT windows optimizations (e.g. black viper), then ran uninstalls again my driver/software installed correctly. Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
#23
Just tried installing 9.02 on my digi003/9.01 install and got the hardware not found error. messed up my whole night playing with the computer instead of making music. Do they have a QA dept in this company?
Now I'm very confused about what firmware and driver I need to get this running again? Are they included in the 9.02 release? all I see is 1 executable. How do i confirm what firmware i currently have and where do i download what I need? Thanks and thank you avid for another beautiful evening |
#24
there is a separate file for the new 9.0.2 drivers for 002/003
you should uninstall the 002/003 make sure your FW card is running the legacy driver as described in the optimization guide turn off the 002/003 install the new 9.0.2 drivers for 002/003 restart and turn the 002/003 back on i had piles of errors before i did this, in this order. PT took a super long time to load but the first time but i haven't had an error since. i think turning it off after uninstalling and leaving it off until the new driver is installed is important cause windows might install the hardware automatically and who knows what driver it'd use. doing the steps in this order seems to be what worked for me. my question is; was there any documentation about this? i looked around a little and couldn't find anything about how exactly to go about this update. ended up with a lot of trial and error for me and many others on this board. and, as the previous poster is an example, it's not even totally clear that there is a new driver, in a separate package. you have to go to a different page and look for it before you even know it exists. |
#25
Thanks for the info.
Do you happen to know what the legacy version is for the driver for the firewire card that i can see in device manager? I bought and installed this 'approved' card along time ago but when I moved to win7 it installed the driver automatically (plug and play). Am I suppose to find an older driver for that card now to make 9.2 work? I'm back up with pro tools 9.1 now. I'm feeling i should stick with it until they get their act together and their documentation. |
#26
I agree with this. Unless you feel you absolutely must have the 9.0.2 update for a particular bug fix, you may be well advised to stay with 9.0.0 or 9.0.1, perhaps with the new driver though.
#27
you will see a list of compatible drivers, probably 3, the texas instruments driver (or whatever card you're using, i have the PT approved TI), and two generic OHCI drivers. one is labeled "(legacy)". click it, and next, and so on. the reason avid is recommending this is it seems there is some change in the way win7 handles the IEEE1394 protocol that can cause lag of some kind that protools might not like. so the legacy version enforces that FW works the way it had in all previous versions of windows. what i'm not sure about is if this is directly responsible for any of the errors we were getting. i'm not here to test every permutation and figure out exactly why each error happened. once i get it to start up and run my sessions i stop poking the damn thing! i merely submit my experience to the hive mind. |
#28
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#29
i hope you're right.
thing is i had previously tried to use the lagacy FW drivers, as per the optimization guide, but found that with those drivers my 002 would constantly loose connection and PT couldn't start (before 9.0.2) so when this update came along i didn't think of trying it again. (at least not 'till it was suggested in this thread) anyway, more sessions tonight and over the weekend that will be stressing this rig so here we go! |
#30
if anyone needs this the latest drivers(v9.0.2.65) for the 9.2 release is here:
http://avid.custkb.com/avid/app/self...p?DocId=379411 |
sync hd...not communicating | Flyingonempty | Windows | 0 | 03-06-2014 08:43 AM |
888/24 and MIX Farm not communicating | audio[LAB] | Pro Tools TDM Systems (Mac) | 8 | 04-24-2008 12:03 PM |
software not communicating with m box | HAIRCUTS91 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-22-2006 05:31 AM |
6.1 LE not communicating with 02 | hutt1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-27-2004 05:34 PM |
My Digi isn't communicating with my Mac??? | adamjames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-05-2003 01:36 PM |
