Mbox 1 phantom power noise issue
Hi all:
I've just searched the forum and this problem has been reported numerous times, but I've not found an official solution to the problem. Has anyone received support directly from Digi on this? Are Digi guys monitoring this forum that could help me? Problem description: When phantom power is enabled on MBOX1 there are noises coming from the headphone jack when the mix knob is in the "playback" position. The noises sound very digital and seem to be related to CPU load, power, or possibly some kind of bus trafic. (I say this because the noise seem to track with things like moving the mouse around.) I'm using Pro Tools 7.1 LE on an AMD Athlon system (don't have the specs in front of me, but it's a Dual-Core above 2 GHz with 2 GB of RAM). Thanks... |
Re: Mbox 1 phantom power noise issue
I remember some Mbox users had success by using a high-quality USB cable(some have better shielding than others) and also bu moving the cable away from other noise makers(like wall warts, line lumps, external drives, etc). Also, which USB port you use may make a difference(you should use a port on the back plane by the keyboard/mouse ports and NOT a convenient front panel port).
After trying numerous USB cables around my house I picked up a Monster cable and the noise is completely gone! I can't believe what a difference this has made.
If anyone wants to try this solution the cable is a "Monster Digital". This is what is says on the package: Monster Cable Prolink High-Performance USB Cable for Pristine Digital Audio - SingleHelix Windings Exceed USB 2.0 Standards - Ultra-Large Gauge Power Conductor - High-Density, Triple-Layer Shielding Rejects Interference - 24k Gold Contact Connectors - 7ft $24.95 (AND WORTH EVERY PENNY!!!!) |
Solved: Mbox - High-Pitched Noise when using Phantom-Power | EVERGLEAM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-08-2007 03:01 AM |
Mbox phantom power issue | ejwells | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-14-2006 03:37 AM |
Mbox + PB 17" 1 GHz: phantom power noise | VanDaven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-17-2005 07:03 AM |
Noise when i use phantom power in PT with Mbox | shynomi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-08-2005 10:13 AM |
MBOX Phantom Power and High pitched noise | GaryGarris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-19-2003 08:46 AM |
