Old 05-03-2012, 12:24 PM
yellow yellow is offline
Default boss/roland/hardware etc..Drum machine as midi controller/trigger into eleven rack
Hi
i think my thread was too specific. i should ask this generally.
how do you get a drum machine to control/trigger drums in an instrument/midi track with a drum vst (like superior drummer 2 or ezdrummer)?
thanks
Old 05-03-2012, 04:59 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: boss/roland/hardware etc..Drum machine as midi controller/trigger into eleven rac
connect it to the computer with Midi over USB or Midi cable to the interface.
Set it up in Midi Studio.
Then basically check the CC#'s of the drum VI and set the pads to transmit the correct # to trigger the drum/cymbal for that pad - repeat until you have all pads transmitting the correct numbers.
The information you need should be in the instruction manuals of the drum machine and software vi, just give them a good read through.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-04-2012, 06:46 AM
thanks benoni
ill give it a shot
i dont have any literature on the drum machine and the lit in pro tools was very general for midi, so i didnt know how to setuup the drum machine/pt settings...
ill keep u posted
Old 05-04-2012, 08:20 AM
nst7 nst7 is offline
Whatever drum machine you have, you should be able to find a manual for it on the internet, usually from the manufacturer's site.
Old 05-04-2012, 03:33 PM
foudn the manual online, and got it working: setup>input devices>external!!!! (not 11r)
Old 09-30-2013, 12:30 PM
moff moff is offline
I know this is resurrecting an old thread, but I have a similar, though more convoluted question...
Before the days of a DAW, I used to use a Roland R-70 (and before that, a SC Drumtraks), coupled to an Ensoniq ESQ-1 for sequencing and drums on demos. I still have all of the data dumps on cassette (yes, they're THAT old ) and/or RAM card, so it can all be dumped back into the devices.
Lately, I've wanted to try to resurrect/re-work some of those old tunes, and in order to save myself some programing time, thought I could perhaps get that MIDI data into Protools (10) somehow.
The question, is how? This was before the days of GM or .mid sequences, so I can't just import a file. Can I just "play" the tunes from the ESQ or R70/DrumTraks into PT over MIDI (and if so, how do I sync the tempo - does PT get "slaved" to the MTC/SMPTE of the Roland/Ensoniq?), or do I do a data dump from the devices and import that into PT?
Help would be much appreciated.
Boss DR-880 (Drum Machine) and Pro Tools New Perspective! Tips & Tricks 6 06-28-2012 08:50 PM
Pro Tools MP 8.0.1 with BOSS DR770 Drum Machine controller SoMedia Pro Tools M-Powered (Win) 1 05-07-2011 08:42 PM
Using protools midi to trigger a drum machine help Dr Scary 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-23-2010 10:04 PM
MIDI Using Boss DR-880 Drum Machine Questions? 100grit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-04-2005 12:50 PM
Can't set up roland r-70 drum machine to work with midi toecat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-07-2000 12:38 AM
