Yamaha O1V as a midi controller
Hi digi
I would like to know whether the yamaha O1V can be used as midi controller for Protools digi001 as well as TDM mixplus. and pls.tell me the connections required. thanks [email protected] & <a href="mailto:s...ahoo.co.in</a> |
Re: Yamaha O1V as a midi controller
Do a search on the PTle Host for Mac forum on 01V controller.
Short answer is you can go to Setups> Peripherals> Controllers and tell PT it's a Peavey PC1600 (or something... the Peavey one). Assign it as the in and out. You may need to configure in OMS and give "Controller" a check mark after double-clicking on the 01V icon. The amount of control is pretty limited. Basically you'll get 8 faders, which is kind of cool. |
This is good news to me. I was told the 01v could not be controlled or be a controller. I will try this.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K Protools 2018.10 HD Native in 1 project suite Eristopher Music |
The 01V can be completely automated via MIDI and a sequencer (Pro Tools).
I've never had success using it (Promix - pre 01V) as a controller while trying to automate it at the same, so it's one way or the other: It can either be the controller or be controlled. |
hello
Another way to control protools (i have PT.LE 5.1.1 with digi001 on my quicksilver G4-867) is to build a remote control map to emulate completely a jlcooper cs10 . The specs are on the "MIDI Controller.pdf" document at digi site. I did it and it works fine : it's not hard to emulate JLC CS-10 because 01V has lots of faders/buttons and you can assign everything you want to them(remote control page of 01V). You can even control plugins,EQs,PAN,sends,etc etc but it's ONE-WAY-ONLY : you can ONLY send information to protools mixer and not vice-versa(01V's faders won't move when you move protools mixer's fader on display of your 'puter with your mouse). You must set CS-10 emulation mode on protools mixer once you configured your 01V. Now i took a motormix and it works far better anyway because it seems "dedicated" to protools. [img]images/icons/grin.gif[/img] regards yamy [img]images/icons/smile.gif[/img] |
Using Yamaha Keyboard as midi controller | Loper7 | MIDI | 3 | 08-05-2013 12:05 PM |
Setting up Yamaha KX-49 midi controller transport controls?? | JLiRD808 | Pro Tools 10 | 0 | 09-28-2012 02:01 PM |
Yamaha O2R as 16 fader Protools MIDI Controller? | swheaton | MIDI | 0 | 07-18-2006 09:56 PM |
Help!!!: The yamaha 01v96 as a MIDI controller | Odd Terje | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 10-21-2005 03:39 PM |
YAMAHA O2R AS CONTROLLER | DESDRUMS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-06-2002 03:46 AM |
