PT LE Won\'t Play
Recently, when I go into a session and hit the play button, it seems like the play button flashes and then the stop button flashes (and pause is displayed at the bottom of the edit screen) right after it. And nothing plays. It seems to go into play mode for a fraction of a second then it pauses.
I'm figuring that I have a preference set incorrectly but I can't figure out which one. Does anyone have any ideas? Thanks, LeonD |
Re: PT LE Won\'t Play
Sounds like you've enabled the count off - it's toggled with the 8 key on your numeric keypad or in the Transport Window (Command+1).
Rail
if you are using 002R and 6.4 le you might see the light flashing on the 002R, you have to restart your computeralso check below the tracks in the mix window see if you have the little page where you can make notes open.
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Thanks for the suggestions.
I ended up powering the computer down completly and booting it back up again. I did this without saving anything in PT. When it came back up, the problem was gone. If it happens again, I'll try your suggestions. FYI, this was with an MBox running the latest PT. Thanks again, LeonD |
Notation view edit while in play cause play to stop working. | soybalm | Pro Tools 10 | 1 | 04-18-2013 11:11 AM |
Is it possible to play a click without pressing play, and have it in sync.... | ALowe | macOS | 5 | 06-05-2011 04:24 PM |
play flashes then stops. session wont play. | hellbert | Windows | 21 | 03-31-2011 10:49 PM |
When press play the stop key lite and play key blinking | Sam Yin | Tips & Tricks | 6 | 12-05-2009 08:26 PM |
I press play, it doesn't play. hehe - any advice? | awritersparadise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-11-2007 05:24 AM |
