Artist Mix: Faders in touch mode are "crancky"
I got myself a 2nd Mix unit. The first one works flawless. The 2nd unit (new, out of the box): while writing automation in touch mode, the faders sometime (quite often) stop writing while still in auto rec, while still touching them. Sometimes it is a physical fight: finger vs. fader motor. So far it didn't happen in latch mode. I work on mac pro, latest Eucon version, latest firmware. Does anyone know what seems to be the problem? All the best!
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap |
Re: Artist Mix: Faders in touch mode are "crancky"
I’ve had faders not write, but never had them fight me before. Even on “read” they still move freely. This sounds more like a hardware issue. Since bought new, I’d return/exchange as soon as possible.
Sent from my iPhone using Tapatalk |
This sounds like the touch sense isn't working correctly. First swap the power supplies and see if that helps. If not I would return.
Thank you both.
Eddie, can it be a ground problem?
Yes..but if the other units are working ok...probably not external
An update: Earth, wind and fire. In other words: the 2nd unit didn't have ground on the AC cable. So far, problem solved.
Thanks.
i have a problem with "Pencil Tool". Why it's always in "square mode" ? | ak11_lin | macOS | 6 | 08-25-2013 05:38 AM |
Switching a HD from "transfer only" to "record mode" | BretFarewell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-16-2010 12:49 PM |
Switching subwoofer from "discrete mode" to "stereo mode"? | Slerker | Post - Surround - Video | 6 | 02-11-2009 07:04 PM |
why isn't there a midi "touch tracks" equivalent for Protools | fathermac101 | Pro Tools TDM Systems (Mac) | 9 | 04-07-2003 01:30 PM |
So Where is this ""WIN2K COMPATABILITY MODE""?? | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2002 03:30 PM |
