Old 12-29-2008, 11:53 AM
Mark Ziebarth Mark Ziebarth is offline
Default Accessing Sends F to J
I'm using Pro Tools HD 7.4 with Command|8 and have a problem with the second bank of sends. I know I can access them while holding the key "Shidt/Add" on Command|8. But: If my mix window in Pro Tools is set to display singular sends like A and F, the display in the software changes from A to B to C if I push the appropriate button on Command|8. This doesn't happen for the second bank of sends. If I remember right, it once worked... I looked through preferences and things but didn't find the clue.
In short: Why doesn't the Pro Tools Mix window change its display if I hit Send "G" on the Command|8. It works on the display of Command|8 but not on the computer monitor. Anyone?
Kind regards
Mark
Old 01-03-2009, 01:42 AM
Default Re: Accessing Sends F to J
bump
Old 01-03-2009, 03:37 AM
clusterer clusterer is offline
Originally Posted by Mark Ziebarth View Post
Kind regards
hi mark,
i guess you are the one who started that thread also at xing; am i right?
i already gave there my 2cents-comment...
good luck!
Mark
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 01-22-2009, 01:41 AM
bump.
Does anyone know if it's possible? Digi?
Kind regards
Mark
Sends default to -inf preference...resetting all sends to 0 Nathan W. Post - Surround - Video 3 07-15-2011 01:10 PM
Accessing Inserts and Sends F-J on 002 therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-22-2009 04:31 PM
Copying Sends Levels between sends Premo Pro Tools TDM Systems (Mac) 11 09-27-2008 11:03 AM
Accessing ADAT with a 96i/o studio410 Pro Tools TDM Systems (Mac) 0 04-25-2008 03:14 AM
Accessing Help with PTLE Soundboy99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-07-2001 10:54 AM
