Clear Edit Selection shortcut
Sorry all if this is a daft question:
Is there a shortcut that clears both the edit/ clip selection on the edit timeline and clears it from the clip list? I am trying to avoid going for the mouse everytime I want to clear an edit selection and go back to the selector tool. For the time-being I am pressing tab (to clear the edit selection) and cmd+shift+D (to clear it from the clip list) |
Re: Clear Edit Selection shortcut
If the whole clip is selected, command+shift+b will clear it from the clip list, which will in turn clear it from your edit window.
If not, press b first, to put a break in the clips, then you can clear it. Unless I'm mistaken, command+shift+d just clears your search result in the clip list, after doing a command+shift+f to find certain clips? I'm not in front of my Pro Tools at the moment...
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Thanls for the input Ryan
No, cmd+shift+b clears the clip. I want to clear the edit selection in both the timeline and the clip list in one go. |
Again, I’m not in front of my pro tools system right now but maybe I’m confused about what you’re trying to do. Give the above a try and you’ll see it clear from your timeline as well, won’t it? I do this command almost daily to clear guide tracks out of adr sessions.
On a Mac, just hit the CLEAR button
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
There might be a setting that has to be checked in order for my method to work
Excuse the computer lag, the screen capture made everything lag but you'll get the idea.
Up/Down arrow to clear edit selection, then P or ; to switch track also works.
In the Digidesign logickeyboard, the Clear button acts exactly like cmb+shift+b!
Up/Down arrow to clear edit selection, then P or ; to switch track also works. Yes, the down arrow is a good option! Better than tab. It does not clear the previous selection on the clip list though... |
But I don't believe that this actually clears any selection in the clips list, FYI. |
Edit selection follows Clip list selection [solved] | HDXSound | Pro Tools 12 | 2 | 09-26-2017 03:02 AM |
Any shortcut to audition selection in edit window? | Tom M | macOS | 3 | 07-19-2013 10:45 PM |
Link edit and time selection shortcut? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-27-2009 01:19 PM |
Shortcut for moving Edit Selection Start to End? | kid pro | Pro Tools TDM Systems (Mac) | 1 | 02-04-2003 11:24 AM |
