Can you import wavs. into a protools session?
Is it possible to import wavs and aiffs into a protools session.. I know theres gotta be a way right?
And also are there any basic tricks to get the program running faster, regardless of computer strength (ours is a 1.6 P4 with the "not DDR (sd?)" memory) Thanks for the help. Peace |
Re: Can you import wavs. into a protools session?
Yes, either file/"import audio to track", or the "import audio" from the menu in the region-window.
What's that? - That's the machine that goes "pling". Bastiaan |
Yeah, I guess part of my problem is that command on my window stays shaded, so it won't work. Is there something wrong with my presets?
You first have to create a new session....
Hello
I beleive this is what you want to get the wav. files in.... File>Import audio to track In the "Look in" box find the drive where the wav. file is located and it should end up in the large box below.Click on the folder that has the wav file in it.Once you see it double click on the wav file so it appears in the middle box and the far box to the right(Region- Import method box).Once you get your file in that box click on "Done" at the bottom right and it will then bring up another box "Choose destination folder".Make sure its the right folder and click on the long bar at the bottom of the box. Hope this is what you needed. DJ
6969 |
Thanks for the help, I got it going now!
Importing a session using XML file and wavs | Kevin P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-23-2012 12:57 PM |
how can I import multiple wavs to one track? | koolaidman | Pro Tools M-Powered (Win) | 3 | 04-28-2010 02:38 PM |
Plays imported wavs, records new wavs, BUT WON'T PLAY NEWLY RECORDED WAVs | cmoseman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-02-2008 10:20 AM |
exporting one session into multiple wavs? help... | chal7ds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-12-2005 08:13 PM |
wavs take too long to import | chucknkd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-01-2001 10:41 AM |
