Question: Shortcut for "Select Next/Previous MIDI Note" - SOLVED
Hi Folks,
I am stuck with a question, is there a way to use a Keyboard Shortcut (or EuCon) to select the next or previous MIDI note, ideally in the Edit Window on a MIDI (or Instrument) track? I can see that with Tab to Transient, the selector will move to the next MIDI note, and that a "Shift-Tab" will then allow you to select the region of a note - but this also selects any other notes in that time selection. What I want is a way to not have to keep using the mouse for simply note selection - I am doing a lot of audio sample spotting, and using key commands with nudging would be ideal. Thanks in advance. Last edited by teedeecee; 05-29-2018 at 08:06 PM. |
Re: Question: Shortcut for "Select Next/Previous MIDI Note" - SOLVED
Literally 10mins after posting this, two days of frustration was relieved when I discovered that the Arrow Keys (left/Right) will do this.
This is after a few days of heavy work, and numerous attempts at searching here and the web as well as the manual. thanks. |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
MIDI editor: display note "names"? | mike_mccue | Pro Tools 9 | 5 | 11-12-2012 04:35 AM |
MIDI note Latency . . . live keyboard playing is a "little behind" | The Zone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-09-2012 05:33 PM |
Random "pre-midi notes" before real note | Mahkyb | macOS | 8 | 02-08-2012 06:36 AM |
"Select All Following" shortcut?! | Vovique | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-21-2010 12:07 PM |
