Waves L2 and Digital Clipping
Yo, my friends. I am trying to master a few songs. I just aquired Waves L2 and am bouncing to disk. I thought the purpose of a limiter was to limit sound so it would not clip. Yet when I bounce to disk and then listen on itunes, turned up, it clips like crap. I do not claim to be a mastering engineer but what am I doing wrong. It is not clipping within PT. But when bounced to disk, ouch!
Any help would be appreciated. Richard
iMac 27/2.66QC/2x2GB/1TB/4850-512 003r - ProTools LE 8.0.3 |
Re: Waves L2 and Digital Clipping
Is the actual audio file clipped or are you just clipping your sound card when you turn it up in iTunes?
Jason Romney Sound Design Instructor North Carolina School of the Arts www.cd-romney.com www.ncarts.edu/ncsaprod/designandproduction |
Sounds like the apple\system volume is at its max, turn it down and Ide bet that will fix your problem, I too had this one a year or so ago, this fixed it.
A Gentleman is one who can play the bagpipes, yet chooses not to. |
Where are you setting the threshold for the L2. Just because you are not clipping the meters doesn't mean you audio will not have distortion. If you limit it too much, thus raising the make up gain a ton in the L2, you will get distortion. Also make sure you do not clip much, if at all, on mix down.
AJ |
...also make sure the L2 is not still on the masterbuss AFTER the bounce, since you are then "crushing" it 2 times!
[img]images/icons/wink.gif[/img] |
I have found that you really can't turn up iTunes without a significant amount of distortion. Best thing to to is to burn a test CD and see how it fairs on other systems.
dk
www.dpksound.com |
Or you could just take a look at it in Peak or even Pro Tools if you import it back into your session. Just zoom in to almost the sample level. If it's clipped, you'll see it. All the peaks will be leveled off at the top.
AJ |
Also, check the preferences in itunes to make sure that the "sound enhancer" option is not turned on. It adds quite a few dB of crap, it doesn't always clip, but if you have a loud song, it will definitly clip.
-Chris
Dual 867 MHz G4 2 Gigs RAM Digi 002 Pro Tools LE 7.4 Event 20/20bas bottle of Johnnie Walker Black behind right monitor |
Digital clipping??? | muse6638 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-16-2005 09:18 AM |
digital clipping 24/48 - 16/44.1 | imi | Pro Tools TDM Systems (Mac) | 9 | 01-22-2003 08:03 PM |
Digital clipping? | 6969 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-19-2002 09:27 PM |
Digital Clipping | DJ Burt | Pro Tools TDM Systems (Mac) | 3 | 12-27-2000 10:29 PM |
Digital Clipping | DJ Burt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-22-2000 01:48 PM |
