Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-04-2018, 10:56 AM
Shan's Avatar
Shan Shan is offline
Default Re: Unable to type C in Comments field
Originally Posted by Vilming View Post
Hi, I'm on Windows 10 (Fall Creator's update). Tossed pref's and created new session with blank non-audio track. Same problem, unfortunately. I discovered that when Caps Lock is engaged, the upper-case C appears normally, so it seems to be the Shift-C combination that is caught by an event listener that should have been disabled when editing in the Comments field.
Actually, I now have this confirmed on my own system. I'll report it. We can use the Caps Lock key as a temporary solution for now.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 02-04-2018, 11:10 AM
Vilming Vilming is offline
Thanks a lot for confirming and reporting, Shane. To your first suggestion, I do run PT as admin, and use English as PT language. I have a Norwegian keyboard setting in Windows. Tried with English (U.S.) setting, but same result.
Old 02-04-2018, 11:36 AM
Shan's Avatar
It's been reported. Use Caps Lock as a temp solution. Hopefully we'll see a fix soon.
Shane
Old 02-04-2018, 06:53 PM
Shan's Avatar
If you use AutoHotKey, you can also setup a creative Hotstring to type in the uppercase "C". The following AHK syntax will create the uppercase character by pressing "c" twice:
Code:
:*o:cc::C
Shane
Old 03-08-2018, 01:02 PM
Shan's Avatar
This issue should now be fixed in Pro Tools 2018.3:
Originally Posted by Pro Tools 2018.3 Release Notes
Shane
Any way to print comments field? [solved] noah330 Pro Tools 12 5 12-06-2015 06:02 AM
comments field bug Zooce Pro Tools M-Powered (Mac) 7 02-01-2012 03:34 PM
Feature Request: Adjustable font size/color/style in comments field Lorenz Tips & Tricks 4 06-16-2009 04:04 AM
Pro Tools 7.1 Comments Field broken MikeWeiss Pro Tools TDM Systems (Mac) 5 04-01-2006 03:58 PM
Digibase Comments Field JohnC Pro Tools TDM Systems (Mac) 5 08-01-2004 01:22 AM
