Old 12-02-2016, 03:07 AM
dkrz dkrz is offline
Default iMac internal mic input and Scarlett 2x2 output?
Basic question here. I'm trying to use my iMac's internal mic to do some rough voiceover mixes while using my Scarlett 2x2 interface as the main output device. I can't seem to figure this out (rather embarrassingly), I've tried several Playback engine selections including Pro Tools Aggregate but with frustrating results. I can get the input set to the Mac's internal mic but then I can't select the Scarlett as the output and visa-versa...
Any help would be greatly appreciated!
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
www.dpkmusic.net
Old 12-02-2016, 03:22 AM
mbreemhaar mbreemhaar is offline
Default Re: iMac internal mic input and Scarlett 2x2 output?
You can make a new aggregate device in Audio/MIDI configuration in OS X. Just make a new device which uses your Mac's internal input and the Scarlett outputs. After that, select it in your playback engine settings and you should be set!
Old 12-02-2016, 04:27 AM
So simple... worked like a charm. Thank you!
www.dpkmusic.net
Using S/PDIF Output with Focusrite Scarlett 8i6 DonaldM Third Party Interfaces 1 10-03-2014 01:13 PM
PT9 Scarlett 2i2 phones output? elmodagansta Windows 5 10-30-2013 07:40 AM
Using internal speakers on imac with PTSE numbertenox Pro Tools SE and Essential (Mac) 2 02-18-2011 02:17 PM
New iMac supports two internal drives! Dism 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 07-30-2010 09:24 AM
iMac Internal Speakers No Devices tsoura 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-20-2009 11:43 AM
