Old 10-27-2009, 10:33 AM
iCymiCy iCymiCy is offline
Default Direct Monitoring with Digi 002 Rack
Hey there everyone,
Im running Cubase 4 on Windows with a Digidesign 002 rack,
i want to make use of the "direct monitoring" functionality of cubase in conjunction with the digi hardware, available in cubase properties.
When the checkbox is unchecked monitoring works fine, except for the delay,
but if i turn it on the monitoring just mutes.. now my questions are:
1) Why is it not working?
2) To which outputs is the direct monitoring signal being sent, only outputs 1/2, all outputs, or can i define that somewhere in an external hardware tool?
thank you for your answers!
Jan
Old 10-27-2009, 01:14 PM
LincolnT LincolnT is offline
Default Re: Direct Monitoring with Digi 002 Rack
Originally Posted by iCymiCy View Post
Hey there everyone,
Jan
It is called "Low Latency Monitoring" when you use the Pro Tools software. Low Latency Monitoring only outputs to outputs 1/2. And it only send the track there if the track is record-enabled and if the track's output is set to output 1/2. There is also an InputOnlyMonitoring option to toggle. I have no idea whether these features are available on Cubase.
MBox 2 Pro connected to motherboard 4 pin firewire port
Dell Inspiron 9300 laptop
2.0 gHz Pentium M
2 gB ram
Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter
Roland 700SX stage piano
Studio Projects C3 mics
Melodyne Plugin
Dual Boot:
PTLE 8.0.1 on Windows 7 Enterprise 32 bit
PTLE 8.0.1 on XP Media Center SP3
Old 10-27-2009, 07:43 PM
albee1952 albee1952 is online now
No slam against the 002, or Cubase, but there are much better choices of hardware for Cubase. DIGI hardware is really best with PT and just doesn't work that well with other DAW programs. You can sell the 002 and get a firestudio that will work much better(or I could trade you for the firestudio I am trying to sell). You can email me at my DUC name at hotmail.
Old 10-31-2009, 07:03 AM
okay, i somehow managed to get the direct monitoring working on outputs 1&2,
is it possible to mirror that output to have the same signal at e.g. outs 3/4?
I want 2 headphones connected to the digi..
Another thing is, i cant control the volume of the monitored signal,
when recording i need to level the "master channel" of cubase down, so the input signal is heard louder..
is there a possibility or workaround to control the input level?
thanks
Direct Monitoring on MAC carbarnrob Pro Tools 10 0 10-24-2011 11:18 AM
Direct Monitoring in Cubase... Carlos Juvandes Pro Tools M-Powered (Win) 1 09-24-2007 12:59 PM
How do I do Direct Monitoring with Digi 003? Steve7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-14-2007 01:06 PM
Direct Monitoring Sean Estella Pro Tools M-Powered (Win) 3 03-28-2007 11:41 PM
Monitoring MIDI with DIGI 002 rack synergy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2006 09:07 PM
