  #521
Old 06-20-2009, 04:21 AM
AndyJCP AndyJCP is offline
Default Re: Play/Pause issue driving me nuts...
Originally Posted by DigiTechSupt View Post
I'm hoping we can get a bit more info from anyone experiencing this issue. If you can answer the following questions, it would help us narrow down all the iterations of this problem.
1. Do you have Error Suppression turned on? If so, disable it - do you now get errors and, if so, what are the error numbers.
2. If you get this problem a lot, can you do a quick-ish test and press play and just let it sit - does it eventually start to play? You shouldn't need to wait more than 6 minutes at 48k or 3 minutes at 96k to determine this.
3. Which Digi HW are you using?
Thanks!
1. I always have Error Suppression turned off
2. Sometimes it starts after 10-20 seconds, but then midi timing is totally off and VIs do not produce any sounds
3. 003Rack
  #522
Old 06-20-2009, 08:13 AM
jeam25's Avatar
jeam25 jeam25 is offline
I ever used the Error Suppression so i turn it off and the error dissapear for a moment UNTIL i changed the sample and tick base option in the midi tracks !! And after close PT and use other app like sound forge and reopen PT again !
I get a -9094 error !
- Jesus Alvarado -
Keep the volume UP !
  #523
Old 06-20-2009, 08:43 PM
jeam25's Avatar
I cant beleive they didnt resolve this YET !!
- Jesus Alvarado -
  #524
Old 06-21-2009, 03:51 AM
MrRippie MrRippie is offline
All I can say is WOW.
Ive had the same space bar, "play" issue for as long as I can remember.
This entire time I thought it was a bad keyboard or something hardware related in my own isolated case.
The worst part is trying to audition sound effects, and having to hit
the play button 1-10 times to get it to play in the import window.
VERY frustrating when you have to audition 100 sounds in a row, then do it all again for the next sound you need.
I came on here just now to see if anyone else has ever had that problem and found this thread that started last year.
My face lit up when I saw 53 pages, I knew there would be a fix by the end of it.
Holy cow, digi once again has blown off a major problem with their code.
This software is a joke. Not only is it seriously behind the times
compared to others out there, the total lack of updates to fix issues
that should have been fixed in version 1.1 and STILL not fixed amazes me.
I own a Sound Devices 788T field recorder, and it blows my mind
that in a years time they not only took an 8 track recorder and made it into a 12 (for free) and added a TON of features (for free)
and more importantly if someone reports an error, usually the very next update
its fixed.
Oh wait, thats how it SHOULD be. My bad.
The sad part is im running 7.4, and if they EVER get around to fixing this 1st grade level issue
you KNOW its only going to be fixed in 8.0 and they ONCE AGAIN will expect
us to pay for ANOTHER upgrade.
(just got my 003 console back from repairs after a YEAR of
MAJOR issues just getting the program started, countless hours wasted..
Turns out it was a bad version of firmware, yet no one could ever
tell me that before?)
  #525
Old 06-21-2009, 04:44 AM
mano111 mano111 is offline
you KNOW its only going to be fixed in 8.0 and they ONCE AGAIN will expect us to pay for ANOTHER upgrade.
Have you tried deleteing the content of the folder 'c:\windows\prefetch'?
this works for me every time on 7.4 even though it seems to come back after a few weeks/months.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #526
Old 06-21-2009, 04:53 AM
hey mano, thanks for the suggestion. May I ask what else would be affected
by deleting that "prefetch" folder?
  #527
Old 06-21-2009, 06:40 AM
AFAIK its some sort of cache that is recreated whenever you run an installed program.
This was sugested as a possible fix by DIGI way back at the begining of this thread.
No one has commented on this so I dont know if it works for others, but like I said it did for me. :)
  #528
Old 06-21-2009, 10:03 AM
after reading this i quickly altered on of my apps to include a function to help this process along. give it a try and let me know if it helps and does the job. there is a read me enclosed in it. PLEASE read it before launching this app.
trasher 3
here is also a shortcut package i have created and working on. i dont work w/o it, others may hate it buyt feel free to check it out and read the readme as well. still a few quirks in it but getting them worked out slowly.
quick key sets
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
  #529
Old 06-21-2009, 06:48 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
quick key sets
I DonT EITHER!!!!
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #530
Old 06-22-2009, 11:39 AM
DigiTechSupt's Avatar
Is anyone experiencing this still using 7.4??
If you are, can you please send me an email with your system info (Sandra report)?
Send to : vi [at] digidesign [dot] com
Thanks!
Avid Audio Tech Support
Support FAQ
Pro Tools 11 Play-Pause Issue ProdGawd Windows 7 12-12-2013 05:22 PM
PLAY / PAUSE - Issue ... Once More !!! Zergei Pro Tools M-Powered (Win) 2 12-27-2009 11:50 AM
Some info on the Play Pause Issue Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-31-2009 05:18 PM
Play/Pause Issue Resolved - Maybe? Try This. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 167 06-20-2009 08:42 PM
cursor issue driving me nuts!! stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2006 03:21 AM
