#31
Re: Play/Pause issue driving me nuts...
I've been having this intermittently too over the last month on my new Quad core 7.4cs7 computer. It was especially noticeable this morning.
I just disconnected the FW drive that I use mostly for transfers since I'm running off an internal SATAII, and it hasn't happened over the last hour or so. Maybe something worth looking into? I'll report back if I see any other change... |
#32
I downloaded the Tech Support folder....extracted everything and when I run the tool it opens a window that says "There doesn't appear to be a valid installation of ProTools". I'm running 7.4cs7 on SP3.
Is there something special I need to do? It looks like i'm not the only one with this issue: http://duc.digidesign.com/showthread.php?t=228749 I don't believe I trashed the prefs last time I moved the plug-ins. Is that different than the "prefetch" file? |
#33
I have the same problem. Really annoying!
Pro Tools 12.4 HDN, PCIe, Omni & Digi 192 ASUS Sabertooth, Intel i7 3820 3.6Ghz 32 GB 1600Mhz Corsair RAM SSD 500GB Samsung WIN 10 64bit |
#34
Reading back through the thread....the common elements i've seen are:
- Intel Quad processors - DDR2 800 Ram - Win XP SP3 - Nvidia 8xxx - Low buffer settings (64 or 128) Once in this state, I see it at higher buffer settings...but not sure i've ever seen it start with a higher buffer setting. Anyone seeing it without one of the things listed above? Looking to narrow the list as much as possible. Also, I checked my IRQ settings and it seems the FW shares an IRQ with some other stuff (looks like usb controllers?). Not sure if that's a red herring or not, but is there a way to isolate that? |
#35
Where do I check for IRQ conflicts?
I just went: Control Pannel->System->Device Manager, but my FW Card isn't listed there. There were no "?"s nor "!"s like there usually are when there is a problem.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
#36
I had this problem and while I'm not sure its 100 percent gone these 2 things have helped.... turn off speed stepping in your bios. Basically your cpu won't run at full speed when idle. Download cpu-z to see how fast your cpu is running at idle. Also, I started overclocking my q6600 to 3.0 ghz, do at your own risk. I was recording a session that had 60+ tracks obviously some were off, but there were about 10 reverbs and a few comp running also, sample rate 64, no probs. My ram is 4 gigs of ddr2 800 vid card ati something... 3gb ram tweak on.
#37
#38
He meant buffer size.
Go back to device manager and, under the view menu, select "Resources by Type." Quote:
On one laptop system I had years ago, the onboard firewire insisted on sharing an IRQ with the video card, so I just bought a PCMCIA FW card and it was assigned a seperate IRQ. You could also mess around with "Standard PC" mode and manually assign your IRQs, but I would not recommend it. stevedresser83, keep us posted on whether or not your issues are still occuring after turning off speed stepping. |
#39
OC doesn't help to avoid this behavior!
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
#40
Digi, any luck reproducing the issue in house? I can stop worrying about this if I know you know about it. If you don't see an issue on your end, then i'll continue to make a case for it. |
Pro Tools 11 Play-Pause Issue | ProdGawd | Windows | 7 | 12-12-2013 05:22 PM |
PLAY / PAUSE - Issue ... Once More !!! | Zergei | Pro Tools M-Powered (Win) | 2 | 12-27-2009 11:50 AM |
Some info on the Play Pause Issue | Fastermouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-31-2009 05:18 PM |
Play/Pause Issue Resolved - Maybe? Try This. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 167 | 06-20-2009 08:42 PM |
cursor issue driving me nuts!! | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-12-2006 03:21 AM |
