Old 02-18-2019, 10:37 AM
bartosz idzi bartosz idzi is offline
Default Re: Final Cut Pro X to Pro Tools
Questions RE: X2PRO :
Is metadata in AAF correctly preserved? Does it retain original TC of audio clips so you can relink with Field Recorder Workflow?
Thank you
Old 02-18-2019, 10:41 AM
José Luis Díaz José Luis Díaz is offline
May be someone suggest it earlier, but why not use EDL (exported by FCX) and EDILoad?
Old 02-18-2019, 10:49 AM
I guess that works, (does it?) Ediload would be on my bill, while X2Pro can be billed to the production as the editor needs it, that's the main reason i guess. But hey, if Ediload works great with FCPX's EDL output i might go that route! Thanks!
Old 02-19-2019, 11:11 AM
babyseal babyseal is offline
FYI, I've used similar app called XtoCC. It creates xml from .fcpxml file. When I imported the xml into Premiere Pro, it was missing some audio clips. But when I imported the same xml into Final Cut Pro 7, it managed to relink those missing clips and export OMF file. And it's around $50.
Old 02-21-2019, 06:32 AM
Thank you babyseal. Good to know a route that 'works'. The problem is with FCP7, i'm not sure it runs on new operating systems from Apple.
Right now I'm trying with Davinci resolve in the middle between FCPx and Pro Tools, but with mixed results. Might have to splurge for that X2Pro....
Old 02-21-2019, 06:35 AM
Does FCPX export EDLs now? AFAIK the *only* thing FC "pro" X can export is XML to communicate to the outside world. Not even EDLs. At least last time I had the "pleasure" dealing with it.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 02-21-2019, 09:46 AM
minister's Avatar
minister minister is online now
Frank is correct, FCPX only does XML. EdiLoad does not read XML's.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 02-23-2019, 12:56 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Yes EdiLoad currently doesn't load FCP-XMLs but you can convert FCP-X XMLs into EDLs with EDL-X.
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 02-24-2019, 12:14 PM
Cheesehead Cheesehead is offline
Hi Michael
My experience of working on 2 features coming from FCP and FCPX is that all metadata is stripped off the rushes in the import process to FCP.
So no field recorder workflow at all is possible, at least I could never get it to work.
Maybe you can get something with timecode only and Ediload, I don't own Ediload and wasn't prepared to buy it.
Also had problems with mixed sample rates and TC's which FCPX allows but is a complete minefield for any file transfer situation.
We used to use Automatic Duck to get AAF's out of FCP.
I'm not sure if that still works with FCPX.
I may be doing another one shortly from FCPX and not looking forward to it at all.
Mac Pro 6,1 12 core, OSX 10.12.5, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.5, PT 2019.5
Old 02-24-2019, 12:20 PM
Ooops, I see this is a pretty old thread that has been revived.
Anyhow, interesting to know if any new workflow methods have come up in the meantime.
HTML code is On
Laying Final Mix to Final Vision Without Re Encoding??? Miker84 Post - Surround - Video 8 10-31-2015 06:36 AM
Final Cut EDL to Pro tools Help Bantom Post - Surround - Video 2 07-31-2013 09:28 PM
Pro Tools and Final Cut mastroiani Post - Surround - Video 6 03-17-2010 01:01 PM
conflict with pro tools and final cut pro Mlanders Pro Tools TDM Systems (Mac) 6 01-12-2006 06:33 PM
Pro Tools 4.5 with QuickTime 7.03 and Final Cut dannio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2006 08:00 AM
