Re: Automation timing issue
both. if you watch the video I posted, you'll see the exact behavior. And it sounds exactly how you'd expect it to based on how it looks.
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Sorry Jimi, I missed the second part of your post. Not sure what you mean though -- can you clarify? Thanks
So, help me understand here, people. Does NOBODY use their controllers to writer fader automation? Is that why this doesn't concern anyone? Nor concern Avid? I'm just not understanding why this behavior isn't more well-known. It'd seem to me that if you're spending $10K+ for a C24, ICON, etc, you'd probably, at least at some point, if not all the time, draw in a fader ride via the controller and find that it just doesn't work properly.
How do you manage that when, say, one Linear Phase EQ alone adds probably 4 times that amount of delay? (not in front of my system to see the actual delay value right now).
some top cats...use the dot auto as opposed to using faders.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Both useful, but hardly interchangeable. Even if you're a "top cat." ;-) And a pretty shameful excuse to give people who just spent $10K+ on a controller for a tactile mixing experience. . . particularly when all the non-"top cats" on logic and cubase are writing automation that plays back in time. . . .
I work in audio post production so I don't need or use plug ins like that.
Granted, you can avoid most delay compensation issues if you avoid any system delay in the first place. But I assume you can see how this would be an issue for people who use Pro Tools as a music mixing/production environment, with plug-ins and such? I'd imagine that's a big reason why the HDX systems were designed with several times more delay compensation ability than the HD systems have.
Timing issue | algy | Pro Tools 10 | 4 | 04-30-2013 02:21 PM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Automation timing problem | WildHoney | Pro Tools TDM Systems (Mac) | 4 | 03-11-2010 03:45 PM |
Issue with setting "Timing" | jambirn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-28-2006 08:57 AM |
5.3.1 timing issue? | da BaSsTaRd! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2002 06:21 AM |
