Old 01-26-2018, 03:19 PM
cmbourget's Avatar
cmbourget cmbourget is offline
Default Re: Pro Tools 2018.1 Cleared my personal settings
Originally Posted by Anthony_Anz View Post
It's possible that EuControl is looking at your old appsetfile. If you navigate to your custom appset folder you will most likely find your original "ProTools 12MAC" appset file. BACK IT UP AND THEN rename it to "ProTools 18MAC"
let us know if that works.
Thank you Anthony, it works here.
  • Pro Tools 2023.12 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Softube Console 1. UAD systems (USB3).
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
Old 01-26-2018, 06:10 PM
Anthony_Anz Anthony_Anz is offline
Awesome, glad you're up and running.. quick and easy fix!
Old 01-26-2018, 08:00 PM
JGM JGM is offline
Originally Posted by WorldStudios View Post
Yes, I remember this procedure faintly from the 11-12 transition... It worked, but not immediately and easily. To get it to work and stick I had to
1 Quit eucontrol and disable EuCon in ProTools-peripherals
2 delete the contents of Dyn appsets in Library/application support/Euphonix
3 Delete the Pro Tools 18Mac.xml from MC-USER-SET-Root n Library/application support/Euphonix/user sets/MC2User
4 Rename the old Pro Tools 12Mac.xml to Pro Tools 18Mac.xml after copying it to a safe location
5 Run protools and enable Eucon
6 Run Eucon
I don't quite understand these instructions. How am I deleting the very file I need to move to a safe location and re-name?
I found 2 files named (Pro Tools 12Mac.xml & 18Mac.xml ) in the folder named Dyn appsets in Library/application. Am I deleting both of these?
I also found a filed named Pro Tools 12Mac.xml in Library/application support/Euphonix/user sets/MC2User.
So which of these files am I deleting and which one am I moving and renaming?
Thanks.
Old 01-27-2018, 02:37 AM
Maro Records's Avatar
Maro Records Maro Records is offline
Thanks.
At first do only what Eddie wrote:
Rename your old PT 12 Appset to 18
For me it was enough to get it work
Maro,
http://www.marorecords.com
Old 01-27-2018, 03:01 AM
WorldStudios WorldStudios is offline
I updated my instructions so there is less confusion about the renaming. I had no idea I was going to write a complete manual and have it vetted and reworked, but it is getting there I hope.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #16
Old 01-29-2018, 07:34 PM
dez811 dez811 is offline
6 Run Eucon
Tried to rename the xml file and it wouldn't work, used the cleanEuphonixSystem
app didn't work my settings would never show. downloaded new xml file from avid and renamed it didn't work couldn't even see some of the default settings on the horizontal and vertical strips nothing there. I'm sure people will say I did something wrong but I've done it many times and I sure don't want to complain before I get told some nonsense from the forum gods so Ill say nothing
rolled back to 12 and all is good it worked the first time, I got my commands back hopefully they will come out with Eucon 3.8 and that will work.
  #17
Old 01-29-2018, 08:03 PM
EddieJones's Avatar
EddieJones EddieJones is online now
I'm sorry to say but yes you must have done something wrong. EuControl uses the name of the Softkey setting file (Appset) to match the DAW version. The previous version is called something like ProTools12.xml but it needs to be renamed to ProTools18.xml for it to work with PT 18. PT18 does come with a default Appset but if you have custom keys you need to do the rename.
EuControl v3.8 does have a load and Save Appset option now so make all this a lot easier. It should be out before the end of Feb maybe a little sooner.
The Custom user-sets are stored here:
Mac OS:
/Library/Application Support/Euphonix/UserSets/MC2User/MC_User_Set_Root/...
Windows 7:
C:\Users\AppData\Roaming\Euphonix\UserSets\MC2User \MC_USER_SET__Root\...
  #18
Old 01-30-2018, 04:39 AM
P_J P_J is offline
4. Rename the old Pro Tools 12Mac.xml to Pro Tools 18Mac.xml after copying it to a safe location
Worked here. Thanks.
  #19
Old 03-02-2018, 11:56 AM
tonepad tonepad is offline
I got this workaround to work on my Win10 PT vanilla install but NFG for my MacPro HD rig (Hi Sierra). Eddie could you guys just fix this please? I can see the older PT 12Mac.xml dated 1/27/18 and the 18Mac.xml dated 1/28/18. Have tried renaming a dozen times. I suppose it's possible that I never changed the Mac side but I've been used to always having a soft button to do a simple open and close of of the mix/edit window. That is now a soft key on page 1. I'm sure many would agree that this should be on a button. No offense, but whoever came up with the new layouts buggered 'em big time. There was really nothing wrong with the soft button approach for main and often used functions such as the mix/edit toggle AND undo/redo which is now accessed by a "modifier" button. Guess I'll have to do my own custom work for the Mac ...AGAIN!
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
  #20
Old 03-02-2018, 12:07 PM
EddieJones's Avatar
The release next week has the new Load and Save As for Softkeys. I don't think we have changed the Appsets for a while ?
Namm 2018 Pro Tools new hardware zavid General Discussion 14 11-17-2017 11:20 AM
Is Pro Tools 12.6.1 cleared to run on OSX Sierra? SteveGarman Pro Tools 12 1 12-14-2016 01:17 PM
Pro Tools crashes when commit is cleared from Undo history Audiofarm Pro Tools 12 69 06-14-2016 01:06 PM
