DANGEROUS Bug - do NOT Delete Unused Regions
Until Digi sorts out THIS BUG I really recommend no one select unused regions, and use the "DELETE" Option, when cleaning up their sessions.
The bug is easily re-produced, as seen at the beginning of the video, but as I've found out (Almost the hard way), and you'll see at the end of the video, this isn't restricted to Elastic Audio Pitch Modified Regions. It seems to be pulling active regions right off the playlist, that is STANDARD audio, and NOT elastic audio. I thought before, the "Work Around" to avoid this bug, was to just "Print" EA regions, before cleaning the session. This shows, that it can show up out of no where. Digi really should issue a technical alert on this one. here, AND in the LE forum. Digi - HERE'S THE SESSION FILE
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Re: DANGEROUS Bug - do NOT Delete Unused Regions
Thank you for the info. Appreciate the effort very much.
Good Looking Out KingFish, that's one of my favorite functions.
Thank You!
Asus P8P67 Pro 3.1 / Intel i7 2600K / GSkill 2x4GB 1600 / Win 7 Pro 64bit / PTLE 8.0.5 / Digi 002R / Reason 6 / Akai MPK61 / KRK V8's / Rane TTM56 / Technics 1200 mk5 / and Stacks of Wax! |
is this only in 8cs2? i did several sessions now in 8 and this never happend to me. indeed dangerous.
and thanks for sharing... |
Thanks King,
thats why I doublebackup my work, including a "daily reel" with date. Before I run the backups I check if really all files are still present.. Would be a shame to overwrite the backup with a busted project.. knock on wood eeek |
USD - no, it's as early as 8.0 No cs
the Elastic Audio example is a guaranteed removal of audio from playlists "in Use" As for the Audio session I just encountered, I can't "Re create it" I don't know what elements caused it... Hopefully by posting the session, it'll help Digi narrow down the culprit. I Always have a safety Backup at the end of EVERY session, but I do admit, if I'm tracking, and I comp together something in the studio, WHILE we're tracking, and I know it's a good comp / Keeper / "The One" - and I feel confident that I'm not going to want any alternative passes to sift through... I'll often, "In the tracking process", Delete Unused Playlists for that track, and Cmd+Shift+U - Cmd+Shift+B - Delete to keep my sessions clean. With this bug, it's possible, that it'll take your comp right out of the timeline, and delete it from disk. I'm obviously changing this workflow, As I recommend any other folks that have this as a regular part of their Tracking, and comping workflow... And I really urge Digidesign, to post a Technical Alert, like the "Inserts F-J" problems they were aware of, and working on - this is much more serious then messed up Automation.
Off topic: Which app did you use to capture your screenactions into a quicktime movie?
Holy crap - that's a biggie!
Thanks for the heads up. |
Thank you very much, is one of my favourite feat.
I'll take care.
Corrado Magalotti Tam Tam Recording studio |
YIKES!
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
how to delete unused regions | shabbar3 | Pro Tools 9 | 1 | 04-21-2013 02:44 PM |
Can't select and delete unused regions | ericstadium | Pro Tools TDM Systems (Mac) | 4 | 08-22-2007 05:23 AM |
Delete unused regions!!!!! | Musicb4hw | Tips & Tricks | 6 | 02-23-2006 12:36 PM |
delete unused regions from whole files, | macmanjams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-25-2005 08:04 AM |
"Delete Unused Regions" is not available | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-14-2003 05:24 PM |
