Tascam Dm24 To Digi002 Rack As Pro Tools Control Surface
Hello,
I could use some assistance setting up my DM-24 as a control surface for Pro Tools v8.0. Below are the steps I've taken so far to no avail. First - My Setup: Digi002 Rack MIDI IN --> DM-24 MIDI OUT Digi002 Rack MIDI OUT --> DM-24 MIDI IN My Steps: 1. Pro Tools 8.0 --> Setup --> Peripherals --> MIDI Controllers: Type = HUI, Receive From = DigiDesign Digi 002 port 1, Send To = DigiDesign Digi 001 port 1 2. DM-24 Machine Control List: State = X, Device = M HUI Emulate, ID = 01, Chase = --, TRA = O (Empty Circle), REC = (--). 3. External Control List: State = X, Device = M HUI Emulate, ID = 01, MIDI Rx = Checked, Screen = (Arrow to Right for sub menu) When I try to enable the TRA, I get "Device Not Active" And in Pro Tools, I get: "Pro Tools is unable to communicate with HUI. Power-cycle HUI and check its connections. Note, If HUI is not in use. update the Peripherals dialog to prevent further warnings. I tried doing a communication test in Diagnostic mode and MIDI Out = Complete/OK. I've also tried swapping out MIDI cables but the original ones are perfectly good. Thank you for any help... |
Re: Tascam Dm24 To Digi002 Rack As Pro Tools Control Surface
2 problems in the DM-24 control list.....
First - Fill the TRA circle - this is for transport control Second - REC should be 1-8 More info here.... It's old, but still applies... http://www.tascam.com/i-890-232-128-1-B419B701.pdf |
Everytime I try to set the TRA, I get the message "Device Is Not Active". Any ideas? |
Pro Tools /Tascam DM4800 control surface | inphazeaudio | Windows | 11 | 12-19-2012 03:05 PM |
Help with Digi002 control surface...(not rack) | Strantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-13-2006 06:56 PM |
Pro tools control surface (tascam us-2400) | Tympanic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-31-2005 09:16 PM |
digi 001 tascam dm24 midi map to control faders | jamarie | MIDI | 0 | 06-14-2002 04:31 PM |
digi 001 tascam dm24 midi map to control faders | jamarie | MIDI | 0 | 06-14-2002 04:29 PM |
