PTLE 6.01cs1: patch names not showing up
Anybody have any ideas why my patchnames aren't showing up on my MIDI tracks?
No matter which patchlist file I load from the DIGI supplied files, no patch names show up-- just the default numbers. I guess that's progress-- before 6.01 I would just crash when loading patch names [img]images/icons/rolleyes.gif[/img] Any suggestions would be appreciated. Thanks, c G4/450 - 1Gb RAM DIGI 001 OS X.2.6 PTLE 6.01cs1
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
Re: PTLE 6.01cs1: patch names not showing up
hi CWHITE771, I HAVE THE EXACT SAME SYSTEM AS YOU AND HAVE HAD THE SAME PROBLEM, FIRST OF ALL YOU NEED TO GO TO MIDI DEVICE SETUP AND CHOOSE THE INSTRUMENT YOU HAVE AND MAKE SURE YOUR MIDI CHANNELS YOU WANT THE INSTRUMENT TO RECIEVE ON IS SELECTED AND THE CHANNELS THAT YOU WANT PROTOOLS TO RECIEVE ARE ALSO SET, THERE ARE OTHER OPTIONS TO CHOSE THERE, SELECT THEM IF YOU WANT THOSE FUNCTIONS.THEN GO BACK TO NORMAL MIXER WINDOW AND CHOOSE THAT INSTRUMENT IN PROGRAM CHANGE WINDOW IN A PARTICULAR TRACK AND YOU SHOULD SEE YOUR PATCH NAMES OF YOUR INSTRUMENT.
IF YOU ARE FORTUNATE YOUR INSTRUMENT PATCH NAMES ARE SUPRTED BY OSX AND ARE AVAILABLE TO USE IN PROTOOLS I HAVE NOT HAD ANY LUCK, ALL MY INSTRUMENTS THE PATCH NAMES HAVE NOT BEEN SUPORTED BY PROTOOLS YET, BUT I HAVE SUCESSFULLY LOADED SIMILAR INSTRUMENTS PATCH LISTS. VERSION 6 PROTOOLS HAD PROBLEMS WITH PATCH NAME FACILITY THEY HAVE FIXED IT IN V6.0.1 BUT I STILL THINK THEY NEED TO WORK ON THE MIDI SIDE OF THINGS BECAUSE I HAVE FOUND NUMEROUS PROBLEMS WITH 6.0.1, I'L BE PATIENT AND WAIT FOR THE FIXES HOPEFULLY I,L HAVE A FULLY WORKING VERSION WITH MINIMAL BUGS BEFORE I LOOSE INTEREST IN MUSIC OR DIE OF OLD AGE GOOD LUCK DAMIR |
Thanks for the reply damir. I haven't had the time to mess around with it yet but, I'll see what I come up with when I can. I will be a fine day when the bugs are gone-- support for more MIDI devices would be nice, too.
--- c
http://digicake.com/midnam/ Then download MOTU.sit and you will find many extra patch names.
- Jason |
I created my own .midnam file for the EX but I can't tell if it's working or not (hence this thread) because PT6.01cs1 doesn't seem to load any names from any .midnam file (for me at least).
OK, after messing around with the Audio MIDI Setup a bit I was finally able to load midnam files for some other synths into PT6.01cs1. However, there still seems to be an issue with the midnam file that I created for my EX5 since PT "unexpectedly quits" everytime I try to load it (at which point I have to go and reconfigure my Audio MIDI Setup which gets corrupted because of the error).
I'm not exactly sure what's wrong with my midnam file-- I've looked at a number of others and tried many different things and still no luck.
Make sure you don't have special characters >, < or & in your file. If you want them in your file, check some of the existing patchname files to see how they are added to patch names.
--- c
Hello, I'm trying to get Kurzweil K2VX patch list to show up into PT 6.0 so is there a web site or does Digidesign have instruction on their web sit explaning how this works? ray
iMac Intel Core 2 Duo 2.7 GHz OSX 10.6.2 M-Box 2 ProTools 8.0.3 MacBook Pro Intel Core 2 Duo 2.2 GHz OSX 10.6.2 2 GB Memory 200 GB 7200 internal drive M-Box 2 Mini ProTools 8.0.3 |
Open PT. (you may have done this already) Go to Setups (top menu) --> Edit MIDI Studio Setup... Add a new device-- in your case the K2VX (looks like it's supported-- the files are there). Connect it with the virtual cables to your interface in the MIDI setup window. Next, open or create a session in PT. Add a MIDI track. In your MIDI track (in your Edit window), you'll see a box that says "none". Click that and it'll open a window. Then click the "Change..." button. Load the midnam file that corresponds with your synth. It should be located at: /YourDrive/Library/Audio/MIDI Patch Names/Digidesign/Kurzweil/K2000VX If you're lucky, the patch names should show up replacing the numbers. If not, you have the same problem I do-- ie. it doesn't work. --- c
Ground Control patch names = 11R patch names? | drebin | Eleven Rack | 5 | 11-23-2010 12:54 PM |
I can't get MIDI Patch Names. PTLE crashes | JoeLouis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 05-16-2009 04:17 PM |
vst's showing patch names | chazc080488 | Virtual Instruments | 4 | 08-25-2008 02:50 PM |
PLEASE: PTLE - XP Patch Names & Banks | Zoduati | MIDI | 0 | 05-21-2003 04:58 AM |
Patch Names for PTLE 5.3.1 | nated86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-24-2002 11:28 AM |
