Old 01-22-2024, 10:49 AM
jeff markham's Avatar
jeff markham jeff markham is offline
Default PT won't start with VPN enabled - Solved
Hi All,
After having detected several hacking attempts on my rig, I got a
VPN (Express VPN). While I like it, Protools will not start when it's
enabled.
I can't tell if it's the Pace iLok stuff, Protools itself, or a plugin that's
trying to phone home and can't.
Anybody else seeing this?
The remedy is to disable the VPN while it starts and then re-enable, but
I'm paranoid that something is going to try to phone home in the middle
of tracking.
jeff
Old 01-22-2024, 01:14 PM
off the wall's Avatar
off the wall off the wall is offline
Default Re: PT won't start with VPN enabled
I work on a VPN to my studio in NYC all the time. No issues. It is the stock Apple VPN client to a Cisco router though, not a service.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 01-22-2024, 02:34 PM
dominicperry dominicperry is online now
No problem here with Nord VPN, connected to a different time zone - launch PT, and run the demo song, all fine. I use a physical iLok, not iLok cloud.
I've got plenty of plug-ins, but clearly not used for the demo song.
PT U 2023.12.1
MacOS 13.6.3
You could try installing Little Snitch or similar to see what's phoning home.
Alternatively, try turning the network off completely and then launch PT....
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 01-22-2024, 05:16 PM
Ok . I'm using ExpressVPN .. I wonder if there's something up with that.
It has it's own client.
I get the never ending bouncing PT icon in the toolbar.
I did a spindump and it appears to be stuck here:
Thread 0x3e59df DispatchQueue "com.apple.main-thread"(1) Thread name "CrBrowserMain" 1001 samples (1-1001) priority 32 (base 32)
1001 start + 1903 (dyld + 25631) [0x7ff808fc441f]
1001 ??? (Pro Tools + 23264) [0x10b666ae0]
1001 LaunchProTools + 5608 (ProTools_Red + 86840487) [0x148aa04a7]
1001 Launch_Pro_Tools(char*, bool) + 46 (ProTools_Red + 86834669) [0x148a9eded]
1001 PTLauncher::SetUp() + 224 (ProTools_Red + 86802468) [0x148a97024]
1001 TPACEFusion::IsPACEBaseAuthorized() + 750 (ProTools_Red + 95276452) [0x1492abda4]
1001 OPENSSL_ia32_rdseed_bytes + 1098679 (ProTools_Red + 106704951) [0x149d92037]
1001 OPENSSL_ia32_rdseed_bytes + 784187 (ProTools_Red + 106390459) [0x149d453bb]
1001 OPENSSL_ia32_rdseed_bytes + 734656 (ProTools_Red + 106340928) [0x149d39240]
1001 OPENSSL_ia32_rdseed_bytes + 825002 (ProTools_Red + 106431274) [0x149d4f32a]
1001 OPENSSL_ia32_rdseed_bytes + 153397 (ProTools_Red + 105759669) [0x149cab3b5]
1001 OPENSSL_ia32_rdseed_bytes + 1576387 (ProTools_Red + 107182659) [0x149e06a43]
1001 OPENSSL_ia32_rdseed_bytes + 6317632 (ProTools_Red + 111923904) [0x14a28c2c0]
1001 OPENSSL_ia32_rdseed_bytes + 6314678 (ProTools_Red + 111920950) [0x14a28b736]
1001 __recvfrom + 10 (libsystem_kernel.dylib + 19510) [0x7ff8092e2c36]
*1001 hndl_unix_scall64 + 22 (kernel + 1269174) [0xffffff8000411db6]
*1001 unix_syscall64 + 480 (kernel + 7860928) [0xffffff8000a5b2c0]
*1001 recvfrom_nocancel + 277 (kernel + 7121701) [0xffffff80009a6b25]
*1001 ??? (kernel + 7122059) [0xffffff80009a6c8b]
*1001 soreceive + 2222 (kernel + 7055166) [0xffffff800099673e]
*1001 sbwait + 274 (kernel + 7094594) [0xffffff80009a0142]
*1001 ??? (kernel + 6712359) [0xffffff8000942c27]
*1001 lck_mtx_sleep + 101 (kernel + 1755413) [0xffffff8000488915]
*1001 thread_block_reason + 192 (kernel + 1830192) [0xffffff800049ad30]
*1001 ??? (kernel + 1838425) [0xffffff800049cd59]
*1001 machine_switch_context + 215 (kernel + 2962183) [0xffffff80005af307]
Old 01-22-2024, 05:38 PM
Ok .. I found a work-around .. thanks for the hint . I disabled the ExpressVPN control panel and setup using Tunnelblick using the OpenVPN settings ... and not it's working fine.
Thanks for the hint.
No sound from record enabled track when low latency monitoring is enabled ncsaxman Pro Tools 12 13 06-22-2019 01:35 AM
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 11:06 AM
Downloaded PT 8 and it wont start PT logo moves but doesnt start????????? protonneutron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2008 03:25 PM
Can I start Playback at Session Start Time? LSW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2006 03:04 PM
Pro Tools 5.1 Session Start—Record Start Interval Avid Pro Tools TDM Systems (Mac) 4 04-18-2001 08:27 AM
