Carbon Jitter Specs
I would like to know the jitter specs of Pro Tools Carbon. I am connecting Carbon to a UAD 8. I have a Black Lion Micro Clock MKIII XB external and would like to know if the jitter specs of the Carbon are better than the Micro Clock MKIII XB. The jitter specs for the Micro Clock MKIII XB are 0.6pS RMS (BNC outputs).
Thanks!
Earl Size MacBook Pro Max 64GB ram 2TB SSD, 8TB & 4TB External SSD, Ventura 13.6.6, Pro Tools Ultimate 2024.3, Pro Tools Carbon, Apollo 8 Quad Black Lion Mod, UAD Octo, Avid S3, Avid Dock |
Re: Carbon Jitter Specs
I'd like to know this as well. I haven't seen it spec'd.
Presumably what you also want to know is what is the actual jitter at the converter if you clock the Carbon from the Micro Clock MKIII XB?
Many of us have stopped caring about this, with modern nice system having such low jitter. Avid talking about JetPLL in Carbon would imply it's not going to be an issue, but still a spec would be nice to know, reassurance that nothing got messed up. And be careful comparing jitter specs I don't see clarity from Black Magic about what exact measurement they are quoting. So going to assume that's cycle jitter (should be to be that good). The Avid Sync X spec for jitter for example is 1 ms period jitter measured per AES-12id-2020. Last edited by Darryl Ramm; 09-06-2023 at 02:14 PM. |
Any and all information would be helpful. I have yet to do an actual recording and listening test using both options.
Thanks for the replies!
D-Control/Command Remote Control of Carbon or Carbon-Pre Mic Gain | bigbuddy3 | Pro Tools | Carbon | 0 | 04-27-2023 09:55 PM |
To Carbon or Not to Carbon... That Is The Question... | Sparky1 | Pro Tools | 47 | 04-20-2023 03:32 PM |
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? | pm mastering studio | Pro Tools | Carbon | 0 | 12-22-2022 01:54 AM |
clock jitter mapped against the jitter in your CD Players DAC | sessiondude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-30-2002 07:02 PM |
