Sound 29.93fps to 25fps (or 23.98)
Hello everyone!
I have a film edit on Avid in 23.98fps and the export was done (I don't know how) to 29.93fps. The problem is that we are already working on it. When I export to Avid Media Composer ... (after several attempts) it is still desperately longer than the image ... Do you know how I can do, please? thank you P.S. I have 2 versions image : 25 and 23.98fps (but not 29.93fps) |
Re: Sound 29.93fps to 25fps (or 23.98)
The best way to solve this problem is to go back to the AVID project that the wrong export was created from and export it again so you get the correct frame rate, whatever that is supposed to be.
Is it possible to use Elastic Audio to shorten the audio to match the video? I doubt this is a perfect solution, but it might be acceptable if you are not able to do as CT recommends.
Thank you
Ok,
Now I try to export the project to 23,397fps (the rate at the beginning). My question has evolved a bit [:)] Is it possible to import the old project in the new by adapting it? Thank you |
Your original post said the rate was 23.98fps. Which rate is the project, 23.98fps or 23.397fps? We really need the information you post to be absolutely correct if we are going to help you solve your problem.
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! | abes | Post - Surround - Video | 2 | 03-01-2013 09:36 AM |
can LE without DVTK run PAL 25fps? | drguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-04-2008 12:46 PM |
25FPS and Footage — How? | Dan Pinder | Post - Surround - Video | 2 | 06-11-2007 06:45 PM |
Transfer from 29.97 to 25FPS? | Glitter | Tips & Tricks | 1 | 12-02-2002 01:06 PM |
25fps into 24fps? | Xabi | Post - Surround - Video | 1 | 11-04-2002 03:10 PM |
