Old 07-31-2001, 02:48 PM
pauldrum pauldrum is offline
Default DAE BUFFERS PROBLEMS!
I red everything about system held...try change H/W buffer decreasing or viceversa
but nothing of those articles seems to solve this problem
I made a partition where Win 98 SE is alone with PTLE, I checked DMA drivers, disabled
'note it automatically both vith cd-rom and cdrw, disabled SndBlast 16 as audio interface
(not for Midi) I did'nt used a different plug.in for each channel but I used busses etc. I tried move, fade, trim some regions with no problems but (for example) when i try to REPEAT a region ZZZAAAK! Error come out. Someone may help me please?
Many thanks [img]images/icons/mad.gif[/img]
Old 07-31-2001, 02:59 PM
ReniuR ReniuR is offline
Default Re: DAE BUFFERS PROBLEMS!
Give us some of your system specs, so we can better help you. Are you only using one drive that is partitioned?
-ReniuR
www.disposableproductions.com
Old 08-02-2001, 01:28 PM
ok ReniuR
I have 2 HD 20GB UDMA: on first a made a partitioning of 3,gb called Software in which I installed a non-custom Win 98SE with other pherifericals like videocapture Pinnacle's card other audio software like Acid, Sound Forge etc. AND Wave driver 1.3 for Audiomedia III; about 17Gb (called Multimedia)where I save all my audio and video files (till now)
The "2nd one is partionned in3GB for PTLE 5.1.1 and the others gigas (called Backup)
where I will save PT songs. I can change drivers for save PT songs with no problems.
In Pro Tools drive when Win start I have running ONLY Sistray and Explorer
Sound Blaster is disabled like audio device not for MIDI...I have PIII 550, 278MB of RAM
Cirrus Logic PCI video card, BIOS and I made everything indicated on the Guide as disable 'Note it automatically for both cdrom cdrw etc.
The point is when I run and work with 'Be There' system seems go perfectly, meters of System usage and CPU usage are at a about 30%
with all 24 tracks plus Midi tracks but when I tried to work only with three tracks (for example)Repeat a Region one time, the window with error indications come out.
Hi!
[img]images/icons/rolleyes.gif[/img]
Pro Tools 9 HW buffers joe_04_04 Pro Tools 9 2 12-21-2010 11:49 AM
Anyone able to record with BFD All and HW buffers of 128? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-04-2007 12:39 PM
Anyone successfully using BFD All with low buffers? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2007 10:24 AM
DAE Buffers, CPU, and 6.1 upgrade EricFuller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-28-2003 09:53 AM
So tell me about 8-meg HDD buffers!! Stone Knife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-29-2003 12:56 AM
