Old 08-05-2002, 02:31 PM
voltech voltech is offline
Default H/W buffer size and cpu limit?
Does anyone know what this should be set-up as. My Quicksilver DP800 is pretty fast but afetr I have three plugins up, Pro Tools asks me to increase the CPU limit?
Any help would be greatly appreciated?
Thanks!
voltech
Old 08-05-2002, 04:41 PM
mentalmusic mentalmusic is offline
Default Re: H/W buffer size and cpu limit?
Always put it at 85%
Digi001 * Pro Tools LE v5.2beta * Mac G4 733Mhz * 1.5gb RAM
40gb internal HD * Lacie 40gb firewire HD * Radeon 7000 dual-display
http://www.erikkarter.batcave.net
Old 08-05-2002, 04:47 PM
Ben Jenssen's Avatar
HW buffer is increased if you get reports of the HD not being fast enough.
Set it as low as possible because a bigger buffer means higher latency (the delay between sound going into the 001 and returning out again).
The only time you want to set the CPU usage limit to less than 85% is if you run other applications at the same time, like softsynths f.ex.
Old 08-05-2002, 05:47 PM
Oh, So what should my H/W buffer be set at? It's currently at 512 and I'm not having HD problems? Thanks for the help!!
voltech
Host Processors + H/W Buffer Size + CPU Usage Limit Niner macOS 0 04-23-2013 11:24 PM
Screen size limit dafatboy Windows 5 08-10-2012 09:14 PM
2gb file size limit? James Drake Pro Tools TDM Systems (Mac) 10 10-14-2011 02:52 AM
Increase Buffer size/Decrease Buffer size? kerick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2006 01:00 AM
Increase buffer size...decrease buffer size.... Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-08-2005 08:24 PM
