Old 01-16-2003, 04:42 AM
John H John H is offline
Default "Midi hell" or "where did my keyboard go?"
I've had a problem today of my controller keyboard suddenly cutting out mid session as soon as I get a Hardware Buffer error. I've got the HW buffer set to 1024 samples, the cpu usage set to 85% and I'm using sampletank free in a 24 bit session with only 1 midi track and 10 audio tracks playing back while I play a 2nd midi track on the keyboard.
My guess is that protools does something horrible to the system when it throws up one of those "interuption held off... increase the hardware buffer" type errors. As well as the midi keyboard no longer working after the error, I get a very quiet high pitched whine out of the main outputs.
It shows up as MK-249C normally. I used 'auto-detect devices' in OMS after I'd quit protools and instead of showing up the controller keyboard it showed up 2, MK-249C•1 and MK-249C•2. The C•2 version works as an input device with some software synths, the C•1 version doesn't work at all.
I've only got a 300Mhz beige G3 with 320Mb (Rev A desktop model so 384Mb is my limit) and a USB PCI card. I guess USB would have a slight cpu overhead but I tend to run protools into the ground before I'll start submixing to free up cpu time and the error has never caused such problems that I need to restart to get everything back to normal.
I might try leaving "auto suspend" checked to give protools a bit of breathing room but that's not really ideal either.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 04:04 PM
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 04:42 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 01:13 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 01:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 01:00 AM
