Old 02-28-2018, 02:12 PM
Will11 Will11 is offline
Default Playback Engine Trouble
I just downloaded Pro Tools. When I tried to set up the playback engine, the driver for my ur44 interface was not listed in the dropdown menu. I've downloaded the driver and installed it. I've got an HP computer with Windows 10, i7 processor, 64bit, 16 GB ram. I'm lost here. Please help.
Old 02-28-2018, 06:56 PM
Default Re: Playback Engine Trouble
1-how is the UR44 connected? If its USB, you should check that the Power Management feature is turned off for all USB ports(aka USB Root Hub in Device Manager)
2-open Control Panel>Sound>Properties. Look at what the Windows Default Playback Device is set to. If its set to the UR44, change that to the onboard sound card(leaving the UR44 for Pro Tools, only)
Old 03-01-2018, 08:24 AM
junkgear's Avatar
junkgear junkgear is offline
After trying the suggestions albee mentioned, try holding down the N key while PT starts, which will force a hardware refresh and may help to show your interface in the playback engine.
If you are still having issues, please read the Help Us Help You thread, which has general setup, optimization and troubleshooting tips. It would also help if you provided a SANDRA report so we can tell a little more about your system.
Will
Will
System Details
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Trouble bringing up playback engine on startup boycie Windows 1 05-29-2014 06:49 AM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
trouble with playback engine -6088 BenReevesYo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2007 11:27 PM
trouble with playback engine -6088 BenReevesYo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-05-2007 10:56 PM
