Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-11-2013, 09:16 AM
msp msp is offline
Default two interfaces
in pt 10, how can I link two focusrite pro 40's
Old 03-11-2013, 10:12 AM
Default Re: two interfaces
On a Mac, use the aggregate function. On a PC, I'm not sure you can. Easiest solution would be to use something that allows 8 mic signals to be sent out lightpipe, and connect that the lightpipe input on a single Pro40(maybe this can be done with the other Pro40, but I don't have one and don't know).
Old 03-11-2013, 02:28 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Check this out, there is a manual for connecting two Pro 40's via firewire:
http://global.focusrite.com/firewire...o-40/downloads
I was surprised to find out that you CANNOT use a Liquid Saffire in dual mode, but this manual doesn't state how to set up this system using ADAT. Only using firewire.
Good luck, not sure if that's what you're looking for.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2018.10, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 03-12-2013, 12:21 PM
graveleye's Avatar
graveleye graveleye is offline
doesn't the Pro 40 have an optical in? If so, just plug the 2nd unit into the first via the optical.
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 03-22-2013, 02:58 AM
elliot@focusrite's Avatar
elliot@focusrite elliot@focusrite is offline
Focusrite
Two Saffire Pro 40s can be used in dual unit mode without the need set up any aggregate device or connect one to the other over ADAT.
All you need to do is daisy chain one Pro 40 to the other over FireWire and then into your computer, then MixControl will recognise both units and Pro Tools wil recognise just one device.
The article linked below helps explain how this works;
http://d3se566zfvnmhf.cloudfront.net...aluniteng0.pdf
Elliot // Focusrite Technical Support
Old 03-23-2013, 08:00 AM
Teolin Teolin is offline
Is there any way to pair a non-Avid interface with an Omni to gain more I/O? Tom, I notice you have a Motu in your signature.
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
Old 03-23-2013, 08:19 AM
Meads's Avatar
Meads Meads is online now
Yes, you can via SPDIF (2 channels ) or ADAT (up to 8 channels).
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24
Old 03-23-2013, 08:50 AM
I mean simultaneous I/O above the locked down limit on the Omni which is 8.
Maybe I'm asking if it's possible to have additional firewire or pcie interfaces running simultaneously into a PT HD native session. For example, the Omni and a Pro 40?
Pro Tools 12.4
SSD 500GB Samsung
WIN 10 64bit
Old 03-23-2013, 08:52 AM
Meads's Avatar
No, this isn't possible. You can't use an Avid interface as an aggregate I/O, and in PT you can choose only one Playback engine, so it's either HD or FW/USB.
iMac Pro
- MacOS 10.14.6
- C|24
Old 03-23-2013, 09:15 AM
Okay, how 'bout this? I have a PTHD session open. I record 3 tracks through the Omni. Then I go to the setup menu and choose the Pro 40 as the input device (I don't have one, just making an illustration).
1) Can the input device be changed in a PTHD session without having to restart PT?
2) Can I have the Pro 40 clocked-slaved to the Omni in this imaginary example?
If the above is not possible, can I at least place the Omni on top of the Pro 40 and then using venetian blinds cords, tie them together and paint on the side "The Omni Pro 40 System?"
And when they're tied together can the Pro 40 still be clock-slaving to the Omni?
Pro Tools 12.4
SSD 500GB Samsung
WIN 10 64bit
S3L and other HDX interfaces Ben Krum VENUE Live Sound Systems 3 10-08-2013 12:32 PM
Traditional Avid interfaces vs 3rd party interfaces aftermid Pro Tools 10 9 10-24-2012 01:12 PM
Other Interfaces to go along with the 11R PatriotsBiker Eleven Rack 11 11-26-2011 06:32 AM
RME interfaces pinnacle macOS 2 10-16-2011 12:12 AM
PT III how many interfaces? Micki Meuser Pro Tools TDM Systems (Mac) 2 04-06-2001 01:21 PM
