Pro Tools and real 64 bit
A question: are Protools 8.04, or 8.1, or 9 versions full 64 bit versions?
If I have a sampler installed in Protools HD, can I charge 10 gbyte ram of samples in memory? Now I have installed HD 8.04cs2 in Windows 7 64bit, and Play EastWest orchestra, but I cannot load more than some RAM memory... Protools HD 9 can use more than 3.5 gbyte?? Thanks in advance. |
Re: Pro Tools and real 64 bit
No. PT is 32bit only. The only way you can get more memory for VI use is to use a programme for your VSTi to rewire back into Protools eg Reaper, Plogue. There is more details and information over in the LE conference.
cya Ghengis
Intel I7-930 Asus P6T-Deluxe V2 6gig Triple Channel 1600mhz HD2 PCI, 96 I/O, Command-8 Win7x64 |
FXpansion has a good wrapper vst 2 rtas. Good solution Fonorecord, wish I had thought of that earlier instead of working with only 3.5 odd gig.
That doesn't change anything; its still using PT ram...
Try JBridge, it'll wrap 64-bit plugs to work in PT but still address 64-bit ram. Havent tried it yet myself but will do so very soon.
A great option is VIENNA ENSEMBLE PRO.
this program will access it's own 3 gig of ram and you can have 3 instamces open on the one computer. It can run VST's and it comes with a great Orchestral library too. Also it has a cool function that Let's you run another instance on a seperate computer and via LAN cable brings the audio back into pro tools. very cool. Clcik ENSEMBLE PRO on right... http://vsl.co.at/en/211/497/1329.vsl Good luck, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
actually it accesses as much RAM as needed &|or available...
jBridge is only for VST plugins. There are obviously ways to shoehorn VST plugins into pro tools but they don't always work the way you'd want them to and whether or not jbridge works alongside them and PT reliably has never really been tested AFAIK. It wouldn't surprise me if someone has figured out a way to do it, but Vienna Ensemble Pro is by far the easiest way to do this.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Yep, jBridge is VST only but I heard others are using it successfully with PT via wrapper. Because of its price its a good option for some and a quick fix in certain scenarios.
As for VEPro I dont think there's anything else that comes close. |
Pro Tools 10 is REAL!!! | Abomb97 | Pro Tools TDM Systems (Win) | 0 | 10-20-2011 04:42 PM |
The real difference between the new pro tools 9/HD native vs pro tools 7,8,9 HD!!! | endyo | Pro Tools 9 | 1 | 11-05-2010 09:21 PM |
Real-Time Bounce to Disk...REAL PAIN | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 201 | 07-26-2010 08:12 AM |
Recording in real studio, mixing at home w/ Pro Tools, mastering at real studio | scummyjob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-17-2010 03:02 AM |
Pro Tools NT to Real | mediaartist | General Discussion | 0 | 06-30-2000 07:52 AM |
