Old 01-22-2010, 12:47 AM
summerbankstudios summerbankstudios is offline
Question recall
ok folks need a little help,
if i record a band recording say 5 songs and get to the mixing stage ,i mix the first song adding effects ,eq levels etc... if i then want to add these levels ,eq etc... to there next song is it possible to do this without having manually to write down all the settings and then physically set them in there next songs ? obviously some settings wont be correct for the next songs but the general settings drums bass guitars vox probably will be is there a way to do this? ,
thanks for any help.
Old 01-22-2010, 02:05 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: recall
You need to look at "import session data" it does everything you want!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-22-2010, 01:30 PM
Mark Ziebarth Mark Ziebarth is offline
Default Re: recall
Just to add to what crizdee said,
Import Session Data is a very helpful tool, but you have to be careful with the settings.
If you just want to import the mixer settings make sure you don't import "regions and media", also automation can be a problem.
If you're in a situation where you need some mixer settings and some tracks completely (including regions and media) you need to run "Import Session Data" two times as the settings what to import are global for all tracks to be imported.
Kind regards
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2019, Euphonix MC Control
Recall RFQ Pro Tools 9 1 03-08-2011 03:05 PM
PT9 Academic UK recall God_made_me_do_it Pro Tools 9 4 01-30-2011 10:25 AM
Recall a mix environment?? gabrieljay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-29-2009 06:09 PM
Power Harness Recall of the Recall ! ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 09:06 AM
Mix Recall Jerry K. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-27-2003 07:16 PM
