Old 10-22-2008, 05:49 AM
1ace1 1ace1 is offline
Default RAID or MAC OS Extended when working with final cut and pro-tools??
Here are my specs:
MAC OS 10.5.3, Dual 2.3 GHz PowerPC G5, 4 GB DDR SDRAM,
Pro-tools 7.4.2,
Final cut 5.1.4
Here is my problem:
My Video/Audio drive has been formated as a RAID drive. When trying to set the drive in workspace to become a record drive (by selecting the "r" next to the drive in workspace) the "Computer says NO!"
Is this my solution:
Do I need to reformat the drives as a MAC OS extended volume?
If I do this will it effect the efficiency of Final cut?
Any suggestions would be great
Many thanks
A:)
I Love Audio!!!
Old 10-22-2008, 06:44 AM
mountainman mountainman is offline
Default Re: RAID or MAC OS Extended when working with final cut and pro-tools??
What kind of video are you editing?
If it is SD video you don't need to RAID your drives, but if you are working with HD video it's recomended to use RAID (RAID 0 or 5 depending on how many drives you have).
I'm using the same program versions as you and I have no problems with SD video.
Make sure to backup your video before reformating your drives.
__________________________________________________ _____________________________
MacPro 2x2,8GHz QuadCore | 6GB RAM | 6240GB HD | OSX 10.8.4
ProTools 9.0.6 | Mbox 2 Pro Factory | Music Production Toolkit | Reason 6.5 | Final Cut Studio 3
Roland JX-8P | Event 20/20 Bas
Old 10-22-2008, 06:52 AM
I Though that Pro-tools can only record to a MAC OS extended drive and not to a RAID formated drive.
Is this correct or incorrect?
A:)
I Love Audio!!!
Old 10-22-2008, 07:33 AM
Think I have figured it out.
Reformat the drives as MAC OS extended.
RAID is no use for Pro-tools!
A
I Love Audio!!!
Old 10-22-2008, 09:17 AM
docbop docbop is offline
PT doesn't officially support RAID so the RAID has to be invisible to the OS and PT. That mean hardware RAID. I would only use RAID 1 since RAID 0 is zero protection, and RAID 5 is good for reading data not writing like PT is doing.
Steve B.
If you think you can or if you think you can't, you're right.
Old 10-23-2008, 04:57 AM
Cheers all
A:)
I Love Audio!!!
Pro Tools to Final Cut Pro (Working in 60 Frames) vinlance Post - Surround - Video 14 05-16-2013 11:00 AM
Exported OMF file from protools not working in final cut audionut Pro Tools 9 1 07-09-2012 03:35 PM
Pro Tools Extended Tracks? Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-28-2007 12:16 AM
Format Extended or Extended Journaled for PT6.2.3? AAR Pro Tools TDM Systems (Mac) 3 02-06-2004 07:46 AM
When is a RAID really a RAID? Will this increase track count? ThomCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-25-2000 12:28 AM
