importing audio or midi sends ptle into tailspin
Hello and thanks for the use of this board.
I have... 6.4 PTLE mbox w/usb (not mini or mbox2) XP Pro v.2002 SP1 Intel Pentium 4 2.80 ghz 504mb ram Nothing external 1. I tried to drag and drop ezdrummer files but pc would freeze. That's fair enough because EZD says they are compatible with pt 7.3 and later. 2. Used EZD in Reaper, tried to import my created midi file into a pt track. It would import but PT would react erratically. Intermittently flash white, not play the file, then play the file without trying to make it play. The tabs at top would be accessible but the transport wouldn't respond. 3.So I thought...what about importing a harmless audio file already made with pt? I tried it and got the same erratic behavior. I downloaded an update called "6.4cs9" but was scared to install because I was afraid I might lose my current projects. Any ideas why importing audio causes me problems? Is there a way to upgrade to 7.3 without buying new hardware? Am I going to have to go back to the dreaded drum machine? Thank for any help. PS I looked for sandra lite...i didn't find it...downloaded a version from cnet...would not run on my pc...so I just posted the specs I could come up with. |
Re: importing audio or midi sends ptle into tailspin
It seems to be working now. I started a completely new project and everything loaded correctly. Maybe it was something to do with 44.1 and 44k conversions??? I don't know.
I'd still like to upgrade to 7.3 |
How about a Sandra report on your computer? Each successive version(6 to 7 to 8) has taken more resources to operate, so your system may be better off with 6.4. Adding cs6 and cs9 should not affect sessions at all. They are simply bug fixes and compatibility fixes(so you can use XP with SP3). In any case, you have an ancient(in computer-speak) system and may not have much in the way of upgrade options. PT8.0.1 is the last version that works with the old Mbox and the next version of PT will likely be Windows 7 only. Also, back to ezdrummer, since all its audio is at 44.1K, using it in a 48K session will take much longer for it to load(if it loads at all on 6.4). Maybe you should do your drums in Reaper and record them to audio tracks, then import the audio tracks into Pro Tools?
Hi Albee. Thanks for the comments.
I've tried to run two different Sandra lite programs on my recording pc and neither would work. I think I've resigned myself to using ez drummer with reaper to make drum tracks and then importing the wav files to pt. Not as optimum as could be but I can make do. Since my system can handle the current work flow, I'll probably leave it alone. Thanks again. If I have anymore questions, it's nice to know there are helpful people here who aren't crappy!!! Larry |
Importing Reason midi file into PTLE 6.4 | BlueRondo | MIDI | 0 | 11-29-2004 06:02 PM |
Importing midi files from Finale into PTLE 6.1 | joesmohello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-30-2003 09:54 PM |
Importing & Syncing Audio Via Midi? | Severe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-24-2002 12:17 AM |
Importing from Sound Forge ,midi and audio files | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-17-2002 11:30 PM |
importing reason audio files into PTLE | kris whitten | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-09-2001 10:58 AM |
