#41
Re: Best Systems and Components for Win HD/TDM
I use just an HD core card and have tons of plug-in DSP power for days via the 4 cores of the Opterons. In fact, I'm just wrapping up a massive 85 track mix with this Quad and HD 1 only. Some of my edit sessions have over a thousand edits and cross fades and the system handles it no problem at all. Just amazing. For stereo music production this is way more than I'll ever use. It is also the most stable system I have EVER used for PT LE and PT HD. I have been using it for months now, 12-14 hours a day and not one problem. This thing just amazes me. If you want power, check out that board. It was made for PT. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#42
>>> DIY System <<<
=================== Tyan k8WE s2895 (non raid version) 2 * Opteron 246 Antec TruePower V2.0 550EPS 2* WD 120 gig IDE 2 gig Corsair CM75SD2048RLP-2700/S Gforce 6200 PCIE, fanless Antec Titan 550 2* Artic Cooling Freezer. Lite on CD burner Magma 4slot PCI chassis with granite digital firewire bridgeboard. Logitech cordless keboard and mouse, 19 Viewsonic LCD. =================================== Some Notes: 1. The system ran fine in the chassis, but is not digi approved. I've recently moved onto the MB and am currently having problems (see here 2. The 3rd card interferes with the IDE connector on this MB. I removed the cable puller from the plug on the IDE cable to enable the card to sit flat and straight. 3. The stock fans are very noisy. 4. The case has good airflow and comes with a decent amount of extras, but it a little tight to work in. I'd recommend getting a bigger one with plenty of elbow room, as these MB are heavy and can be awkward to mount. 5. There are plenty of people with these board about, as they cross over into the high end "enthusiast" market. check out k8we.com for more general info. 6. The graphics board is a POS, but is very small, thin, noiseless, runs cool and has digital out. |
#43
I agree with Shane. I'm totally blown away by the sound and performance. I finally updated/reinstalled all my software (the imaging program didn't work for me for whatever reason) and I have everything live as of last night.
WOW...I love my 192 and quite honestly, the sound quality of playback at 96khz is just plain amazing. I was diddling with Timewarp and direct in'd my Moog...amazing. Shane, Where's the actual specs on doing the d-verb test? Step by step? I'd like to bench mark mine and honestly, I'm not getting the same numbers so I'm sure I'm doing something different. thanks! Bodie
i7 950, 12Gb, 3 Tb, Win7-64 and 32bit PTHD 12.7 HDCore 1 & w/002r Macbook Pro 4Gb, 500G, OSX 10.6.2 iMac 3.06ghz, 16Gb, 2Tb, OSX 10.6.2 Minimoog Voyager, Liberation, Taurus, Phatty Korgs, Nords and more Arp 2600s & Ody |
#44
#45
But does anyone know the difference between Tyan Tiger and Tyan Thunder?
Kind Regards Peter www.peterjuulkristensen.com http://www.facebook.com/mixingmusic |
#46
Thunder K8WE has 64Bit PCI-X Slots, Tiger doesnt. Thunder K8WE has SCSI option, Tiger doesn’t. Thunder K8WE has 2 PCI-E Slots with 16 lanes each. Tiger has 1 PCI-E with 16 lanes one 1 PCI-E with 4 lanes only. Thunder has one PCI Slot 32Bit only, Tiger has more. But I only know that my three HD cards are PCI, not if there 32bit? - or PCI-X? Digi? - anyone..
#48
But will my 3 HD (non PCI-e) cards fit in both the Tiger and the Thunder board?
Thunder K8WE has 64Bit PCI-X Slots, Tiger doesnt. Thunder K8WE has SCSI option, Tiger doesn’t. Thunder K8WE has 2 PCI-E Slots with 16 lanes each. Tiger has 1 PCI-E with 16 lanes one 1 PCI-E with 4 lanes only. Thunder has one PCI Slot 32Bit only, Tiger has more. Peter
#49
They layout of the PCI buss will be in there. Shane
#50
Also, I am curious if it would be possible to use a PCI SATA card (for an external solution, if deisred) in the 32-bit slot, and then still retain full HD3 Accel performance, should it work and be desired. Anyone have access to one of those boards at least?
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
Are these pc components ok? | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 08-13-2010 11:20 AM |
need help with HD components | FMR_Crisis | Pro Tools TDM Systems (Mac) | 9 | 04-17-2010 05:07 PM |
What components lie in the most POWERFUL native PTLE Systems? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-28-2008 07:18 AM |
Will these PC components do the job | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-06-2007 08:22 PM |
components | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-19-2001 09:32 AM |
