Old 09-30-2015, 11:05 AM
spenedit spenedit is offline
Default Unable to maintain original timecode locations...
Hello all,
I am having a problem changing my session start time. My current start time is 00:59:52:00, and I want to change it to: 00:59:40:00. I get the following error message:
"Unable to maintain original timecode locations with the entered start time because a clip and/or an alternate playlist would exist outside the session boundaries"
I don't see any clips that would be outside the boundaries. No hidden tracks. My session length is 24:00:00:00. Any suggestions?
Old 09-30-2015, 11:21 AM
trakbytes trakbytes is offline
Default Re: Unable to maintain original timecode locations...
Try changing your session length to 12 hours. Is there anything at the end of the 24 hour session?
Save early and often! (or once a day whether you need to or not...)
Old 09-30-2015, 12:28 PM
Hi trakbytes,
I tried that, only if I change the session length to anything other than 24hrs, I get this error:
"The content in this session extends beyond the bounds of the selected session length. Please choose a session length of 00:00:05:00 or longer."
I don't quite understand what that means, especially since I am choosing a length longer than 5 frames!
Old 09-30-2015, 12:30 PM
Oh, and there is nothing near the 24hr mark. My tracks all end around 2hrs.
Old 09-30-2015, 01:44 PM
Inglesworth Inglesworth is offline
Try looking to see if there are any automation breakpoints close to the 24 hour mark? You said there are no clips, but pro tools does weird stuff with automation sometimes...
Old 09-30-2015, 01:47 PM
Syncrecy Syncrecy is offline
Originally Posted by spenedit View Post
Hello all,
I think you need to start at 01:00:00:00, also, you should ask this question to the guys over on the post and surround side of the fence...
Old 10-01-2015, 08:13 AM
john1192 john1192 is offline
no need to start at hour 1 .. when ever i work with picture my sessions start at either 00:59:00 or 00:59:30 .. was used for run up time on machines chasing .. i.e.: Digibeta / DA-88 - it takes a few seconds for these to line up and run in sync ..
just my .02
also: yes, there must be One Thing that is b4 or after your timeline to get a message like this .. breakpoint or something ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 10-01-2015, 02:31 PM
Well, you could make a new session at 0:00 hour start and import your session data into it. There must be something in your original session that would be pushed beyond the 24 hour mark if you change the start time earlier.
Old 10-02-2015, 11:43 AM
Yes, ultimately I made a new session and imported the session data and that seemed to work. I would like to know why it was happening though. I tried this session in PT11, and did not get the same problem.
Old 10-02-2015, 01:02 PM
elicious elicious is offline
fwiw, i change time code settings often,
as a way to "zero" my counter,
when artists reference the mix with comments
relating to the time shown on their player.
and every time, that prompt pops up.
and, every time, i clic past it and never has there been any drama… for me…
your mileage may seriously vary…
e
ihatetyping
import OMF & maintain original timecode pietro79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-11-2010 04:49 AM
import OMF & maintain original timecode pietro79 Post - Surround - Video 8 01-11-2010 01:26 AM
Unable to maintain external clock w/002R generic1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-12-2005 05:25 PM
Recording Original Timecode from DAT h1ntOn Post - Surround - Video 4 07-13-2005 10:45 AM
Maintain timecode when changing session start time Jake Jackson Pro Tools TDM Systems (Mac) 9 05-23-2005 08:43 AM
