Old 03-21-2015, 12:03 PM
greenglassdrum greenglassdrum is offline
Default How to delete old IO paths from track output selection
My rig lost its IO settings I was using.
So I made new ones and got it working.
Now when I go to a track and press on output box, the old paths that I am not using,
(they are labeled as inactive or n/a,) are still there.
Can I remove those old paths?
Thanks
Pro Tools: 10.3.10
Computer: Mac, 21.5", Mid 2011
OS 10.7.5, (11G63), Processor: 2.8 Ghz Intel Core i7
Memory: 16 GBnRam, 1333 MHz, DDR3
Interface: Focusrite Liquid Saffire 56, Mix Control 3.4
Main Hard Drive: Lacie Thunderbolt
Back Up Drives: Lacie Firewire
RTAS Plugs for samples, Native
Old 03-21-2015, 12:33 PM
Drew Mazurek's Avatar
Default Re: How to delete old IO paths from track output selection
Go to the I/O setup page/Buss Output page. Here you can manually deactivate them or just hit default and PT will map your internal outs to all available hardware outputs.
www.drewmazurek.com
Old 03-21-2015, 01:25 PM
Thanks,
When I delete a path, it goes away in the IO set up. Gone.
However it still shows up as an option to select in Track Window output choice.
The one thing I noticed was I am using Sapphire Mix Control 3.5 that is really for Yosemite. I am not using Yosemite. I am Mac OS 10.7.5.
I should be using Mix Control 3.4.
I accidentally updated it.
Not sure how to go back to 3.4.
I have contacted Focusrite.
Thanks to all
scott
Pro Tools: 10.3.10
Old 03-21-2015, 01:35 PM
anothercolour anothercolour is offline
After deleting the unused outputs in the I/O settings, you might want to try selecting the new output on the track, saving, and then closing and quitting Pro Tools.
Old 07-06-2016, 09:29 AM
the hecksome the hecksome is offline
I'm having the same issue, the old outputs are still there, even when deleted from the i/o. Any other suggestions?
Old 07-06-2016, 10:56 AM
Are you deleting from the Bus tab? That's where they should be removed from. when you open setup>IO and select the Bus tab, click on the right side column header(Mapping to Output) until all your output paths are listed in a row. all the inactive ones will be in italics. Select and delete from any/every session that shows them.
Old 07-06-2016, 01:03 PM
Genius! I've wondered how to do this for years. Thanks!
Old 07-06-2016, 06:31 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
I still can't wrap my head around why some current projects I run show all the other project's busses and others show a limited amount.
Old 07-24-2016, 11:17 AM
juniorexploder juniorexploder is offline
Likewise. I cannot for the life of me figure out why previous paths (which I have manually deleted in I/O Setup) keep showing up in my "output" selection menus (albiet grayed-out and in italics)
ANYONE?
Old 07-24-2016, 11:26 AM
Are you saying that there is no "global" way to delete old/unused paths in I/O setup? If I'm reading your post correctly - I actually have to go thru each session individually and do this? I have tried saving and re-importing the I/O settings in the I/O setup - still shows about 100 previously deleted paths in "output".
My input & bus menu's seem to be cooperating with the manual path editing- however ALL output menus still show reams of ADAT's AES/EBU's, SPDIF which are not only not available- I've never had any ADA interface that did! (I am on a Burl MS via MADI currently- however in the past year I've used an Orion32, and Aurora16)
Editing in Protools 10HD - Track Selection Linked to Track Output Window? day_tripper Pro Tools HDX & HD Native Systems (Mac) 0 09-17-2014 10:33 PM
Inserts unavailable: output paths already in use Jack Ruston UK Pro Tools TDM Systems (Mac) 0 12-15-2010 02:50 PM
Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1 Berrado Pro Tools TDM Systems (Mac) 12 06-11-2007 11:35 AM
LIVE on a INST. track..MIDI output selection? geg Pro Tools TDM Systems (Mac) 2 09-02-2006 01:48 PM
How do I select multiple output paths? syra Pro Tools TDM Systems (Mac) 5 10-21-2003 12:39 AM
