Old 02-07-2011, 09:41 PM
philster65 philster65 is offline
Smile Eleven Rack with 003
Ok, how do I connect and operate my Eleven Rack with my 003?
Old 02-08-2011, 04:01 AM
crashhak crashhak is offline
Default Re: Eleven Rack with 003
This is thread posted by Benoni previously, it helps a lot.
http://duc.avid.com/showpost.php?p=1664299&postcount=8
Old 02-08-2011, 10:03 AM
paul_g paul_g is offline
Here is a link to the videos done by Benoni
http://duc.avid.com/showthread.php?t=291589&page=2
Mid-2007 2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.3.10
PreSonus DigiMax FS
Dynaudio Monitors and KRK Sub
Line6 HX Stomp
Old 02-08-2011, 02:38 PM
Benoni's Avatar
Benoni Benoni is offline
As mentioned above there are instructions posted and videos on how to do this.
In the Text instructions i use the 11R as internal and the 003 as external and in the videos I set the 11R to external and the 003 to internal, and I've pretty much started to keep the 11R on External and the 003 on Internal, but you can do it both ways.
Eleven Rack Tutorial - Hook Up To Another Interface With S/PDIF
and instructions to Re-Amp when using another interface (not the 11r) as your Main Interface
Eleven Rack Tutorial - Re-Amping With S/PDIF Part 1
Eleven Rack Tutorial - Re-Amping With S/PDIF Part 2
Eleven Rack Tutorial - Re-Amping With S/PDIF Part 3
Old 02-08-2011, 10:51 PM
Hey Benoni, thanks so much for your help. I've done everything in your vid, with was very helpful BTW, unfortunatley still no joy. What am I doing wrong?
Old 02-09-2011, 03:43 PM
Benoni's Avatar
I have no idea. Maybe if you tell me the problem
Im just guessing from your Youtube comment that you need to default your I/O
Old 02-21-2011, 10:51 PM
Oh yes the Default> Thanks, that fixed it
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven Plugin as Eleven Rack replacement pureanalog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-03-2010 01:57 AM
