Old 04-15-2010, 11:02 AM
Matthew Steel Matthew Steel is offline
Default Defaults for new session dialog?
Is there a way to specify the default settings (sample/bit rate, I/O setup, etc) for the New Session dialog?
It seems that the defaults are whatever was last used. Usually this is OK, but sometimes we'll open a session from somewhere else, or use a different sample rate than we normally use. Then if "somebody" blindly clicks OK without perusing the settings then it causes grief. I'd like to set a default sample rate, bit depth, or at least have my "Standard Settings" to be the default I/O Setup if there is a way.
(BTW we are still on 7.3 on 10.4 on a Dual G5 Power Mac)
Old 04-15-2010, 11:21 AM
Daniel Sasso Daniel Sasso is offline
Default Re: Defaults for new session dialog?
you can always create a session, and then in Finder, select the session and press Command+I (Get Info). Check the box Stationary Pad or Locked, I don't remember, but one of these option should solve your problem.
PT HDX2 ExpressBox EB7 Chassis 10.3.10.D-Control.HD I/O.SYNC H/D.MacPro "4,1".2x 2.26 GHz Quad.32 Gb RAM.OS 10.7.5
PT HDN 10.3.8.D-Command.HD I/O.SYNC I/O.MacPro "4,1".2.8 GHz Quad.32 Gb RAM.OS 10.7.5
PT HDN.PCIe 10.3.8.C|24.HD I/O.SYNC I/O.MacPro "4,1".2.8 GHz Quad.32 Gb RAM.OS 10.7.5
Estúdio JLS Facilidades Sonoras
São Paulo - Brazil
Old 04-15-2010, 03:02 PM
Drew Mazurek's Avatar
Read about Templates in the Manual. You can make your own and have PT start up with the Templates window showing all you self made starting points.
www.drewmazurek.com
what is up with the session I/O dialog upon opening a session Rectifried Pro Tools 11 22 06-09-2015 08:07 AM
Import session data defaults idris Post - Surround - Video 6 03-08-2013 06:56 AM
Session defaults back to 120 bpm????? 440Hz Pro Tools M-Powered (Mac) 1 12-17-2008 08:22 AM
PT 7.1 "Closing Session" dialog JKD99 Post - Surround - Video 3 09-10-2006 03:18 PM
Problem #1: Session View Defaults to MIDI Event bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2006 12:11 PM
