Old 12-18-2008, 06:13 PM
Jantzen Jantzen is offline
Default Pro Tools 8 Waveform View
It is SO different it makes it unusable. The very low volume waveforms are still shown as a thicker line over the central thin line. Even zooming out is useless as as long as it's above some threshold, it remains visible. In older versions, when zooming out these will disappear.
Digidesign please fix this. This makes editing a bitch, especially the subtle things such as breadth.
Jantzen
Mac Pro 8-core 2.8GHz
Pro Tools 10 HD
Old 12-18-2008, 07:09 PM
PaulV's Avatar
PaulV PaulV is offline
Default Re: Pro Tools 8 Waveform View
It sounds like the waveform outline isn't to your liking; you can turn it off by going to View->Waveforms->Outlines and unchecking that option.
Cheers,
Paul Vercellotti
Avid Engineering
Old 12-18-2008, 09:19 PM
groovebrother groovebrother is offline
Question Re: Pro Tools 8 Waveform View
hello,
is there a way to get back the white screen in the edit window ?
and also, the white around the colored waveforms ?
because now the hole interface is very dark and very hardly readable esp. the grid and subdivisions
the 3D interface has almost dissapeared
unless i missed something in the display preferences do something digi : let's have the choice to have the old interface look (esp the edit window ... mabe, i can get used to the mix one ...)
please please please ...
Old 12-18-2008, 11:17 PM
Originally Posted by PaulV View Post
It sounds like the waveform outline isn't to your liking; you can turn it off by going to View->Waveform->Outline and unchecking that option.
Nope it is not that. It's still a problem with or without the option checked. The problem is that, there is a certain range of very low signals that cannot be zoomed out at all. No matter how much you zoom out you still see them on the waveform overview. In 7.4, this was not the case.
Jantzen
Pro Tools 10 HD
Old 12-19-2008, 04:40 AM
Drew Mazurek's Avatar
You are in the minority. Most people were clamoring for more resolution, so that you could see low level info even zoomed out.
www.drewmazurek.com
Old 12-19-2008, 05:07 AM
nucelar's Avatar
nucelar nucelar is offline
AFAIK they upgraded the waveform overview resolution from 8 bit to 16, allowing to see much more low level detail. Can't see the drawback really.
Another thing is if the rendering is correct. Very low levels should dissapear when the track height is reduced. (and viceversa)
cheers
Old 12-19-2008, 07:54 AM
25ghosts 25ghosts is offline
Originally Posted by groovebrother View Post
hello,
Open the color palette window and crank up the brightness - That should get you a "whiter" appearance.
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 12-19-2008, 10:51 AM
DigiTechSupt's Avatar
Nucelar is correct. Waveform Overviews in Pro Tools 8.0 are drawn with 16-bit depth.
Avid Audio Tech Support
Support FAQ
Old 12-19-2008, 01:01 PM
thanks Ghost, that i already did but not enought. Besides i'm trying to find a way to get back the white apparence of the edit window's main screen, not the tracks itselves. you know, i'm talking of the screen section that has the grid lines in it ... the audio regions etc...
will this be the final look of the edit window ?
i really do think that this interface became harder to read because of the new colours. don't you think that the white in the edit window was ONE of PT's great visual advantage on all others ?
Old 12-20-2008, 04:17 AM
hello, am i the only one that finds the edit window became harder to read ?
a question I've always had about waveform view cdmstudios Windows 4 04-14-2011 09:11 AM
Spectograph view in addition to waveform view? digidesigner Pro Tools TDM Systems (Mac) 1 10-20-2010 09:08 AM
Waveform View Sizing danander11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-26-2008 02:42 AM
waveform view during recording sonuslab Pro Tools M-Powered (Win) 2 09-21-2006 09:04 AM
Waveform --> Volume view ??? Brian Kingman General Discussion 2 11-12-2000 04:46 AM
