Old 02-26-2008, 06:08 AM
TimmyP TimmyP is offline
Default Tick timebase - Problem separating regions after Loop Record
Mbox 2
Pro Tools LE 7.4cs2
Win XP SP2
2GB Memory 3Ghz processor
Pro Tools produces an error message when I try to separate the regions created by loop record. The problem occurs only on Tick timebase tracks (not Samples timebase). To reproduce:
1) In preferences->Editing set all 3 "Matching Start Times" Takes list" to on
2) Create a new track (Mono - Audio - Ticks) - Note it must be Ticks
3) Set record mode to loop record
4) Hit record and record a minimum of 2 loops of audio in one go onto the new track
5) Now make a selection on that track with the selector tool and then choose Edit->Separate Region->At Selection
6) The region separation is not successful
7) An error dialogue is returned saying "Could not complete the Separation Region Command because ... Assertion in ...Time_Typed.h line 305"
This behaviour is not explained in the documentation that I can see.
Any ideas on this would be very interesting.
Thanks,
Timmy
Old 02-26-2008, 05:14 PM
Default Re: Tick timebase - Problem separating regions after Loop Record
I just tried to replicate that and encountered no such error. What troubleshooting steps have you taken in order to clear this issue?
filosofem
Aaron Mulqueen - 001 HD Native
Really annoying problem when separating regions. ZebedeeSound Pro Tools 10 7 03-13-2012 12:42 PM
Going through takes from loop record and the regions move out of time... luisam Pro Tools 9 0 02-03-2011 12:45 PM
Separating regions with memory locations tho3hite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2009 04:11 AM
separating regions into songs nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-13-2003 05:46 AM
digi 002 rack - tick, tick, tick, tick, tick osset 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-20-2003 04:20 PM
